Fuel Pump Problem - Weird Priming Noises On Cold Start, Fine Once Warmed Up?
Hey all,
Have a small problem regarding the Bosch 040 pump since installed. On a cold start when I turn the key to reds/ignition the pump makes weird noises when priming. Instead of the usual buzzing/whirring it makes weird knock like noises, reminds me of my friends description of indigestion noises. It sounds like it works, stops, works, stops, works stop giving off a knocking noise.
The noise however doesn't occur anymore after you've driven the car for abit i.e after its actually warmed up. Once the car is warmed up it'd make a normal priming noise of a constant buzzing for a few seconds then just stop.
Any ideas of what this could be? I'm hoping direct feeding a 13.8v power source to the pump will solve this issue.
Oh and when I installed the pump I warpped the pump in a rubber layer so it wouldn't make any noises, could this potentially be causing the problem or another problem?
Thanks!
Andy
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
