Looks good.
Tommy Kaira Aspects.. interior shots please :thumbsup: and engine.
Interior is pretty standard FOR THE TIME BEING!!
After i finish with the interior pics will be posted up
Also thinking about a Z-Tune Carbon Bonnet any suggestions or could anyone PHOTO SHOP one against my car??
Thanks
Howie, was the GTS-R badge $20 from powerplay??
hmmm... my car needs something in that space.... maybe that'll do the trick.... i guess it's a legit badge as it is the GTS-R kit :thumbsup:
is your grille/mesh stuff the factory stuff? I'm trying to find some OEM GTR mesh/grille, but not having much luck. Everything about the East Bear kit was absolute quality...except the mesh :(
They sell the GTS-R East Bear Badges at Century city in springvale and their other store in footscray.(They are proper east bear product)
and yes i too have been hunting everywhere with no luck for the oem mesh.
hey GUYs and GIRLs,
Last year i decided to keep my Tommy Kaira R34 GTR!
But from the day i bought it i had my own modification that i wanted to do !
So i have lately been building it to my specs,
Carbon Fibre front V-Spec front lip
Nismo side skirts and rear pods
Ganador Carbon mirrors,
Nismo Carbon rear wing lip,
Nismo Carbon A-pillar garnish,
White TE37,
Ap Racing 6 pot pistons
Nismo N1 fron bar cut outs,
Nismo Carbon intercooler surrounding
Nismo Clear Side indicators
Nismo Clear front bar indicators
Tell me what u think
Thanks
PIC R NOW UP GUS!!!!
Those white TE37's go so well with the Bayside Blue :thumbsup:
Isn't the interior of the Tommy Kaira different?
I remember the R33 GT-R Tommy Kaira was. Or something.
The 2 front seats are different and the dash is electronic
But besides that, nothing is different
Im wanting to get 2 front BRIDE seats in blue.
I think that will look yummy!!
R-spec, awesome looking car mate, i think the black and red rims suit way better. If it was me though, id remove that rear bar, and replace with a standard, or gtr or something other than the nismo one :)
then id add eye lids and replace the wing :( ((( to me the r34 just doesnt look the same from behind without the wing IMO)))
still awesome car, keep it up :huh:
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
