Looks good.
Tommy Kaira Aspects.. interior shots please :thumbsup: and engine.
Interior is pretty standard FOR THE TIME BEING!!
After i finish with the interior pics will be posted up
Also thinking about a Z-Tune Carbon Bonnet any suggestions or could anyone PHOTO SHOP one against my car??
Thanks
Howie, was the GTS-R badge $20 from powerplay??
hmmm... my car needs something in that space.... maybe that'll do the trick.... i guess it's a legit badge as it is the GTS-R kit :thumbsup:
is your grille/mesh stuff the factory stuff? I'm trying to find some OEM GTR mesh/grille, but not having much luck. Everything about the East Bear kit was absolute quality...except the mesh :(
They sell the GTS-R East Bear Badges at Century city in springvale and their other store in footscray.(They are proper east bear product)
and yes i too have been hunting everywhere with no luck for the oem mesh.
hey GUYs and GIRLs,
Last year i decided to keep my Tommy Kaira R34 GTR!
But from the day i bought it i had my own modification that i wanted to do !
So i have lately been building it to my specs,
Carbon Fibre front V-Spec front lip
Nismo side skirts and rear pods
Ganador Carbon mirrors,
Nismo Carbon rear wing lip,
Nismo Carbon A-pillar garnish,
White TE37,
Ap Racing 6 pot pistons
Nismo N1 fron bar cut outs,
Nismo Carbon intercooler surrounding
Nismo Clear Side indicators
Nismo Clear front bar indicators
Tell me what u think
Thanks
PIC R NOW UP GUS!!!!
Those white TE37's go so well with the Bayside Blue :thumbsup:
Isn't the interior of the Tommy Kaira different?
I remember the R33 GT-R Tommy Kaira was. Or something.
The 2 front seats are different and the dash is electronic
But besides that, nothing is different
Im wanting to get 2 front BRIDE seats in blue.
I think that will look yummy!!
R-spec, awesome looking car mate, i think the black and red rims suit way better. If it was me though, id remove that rear bar, and replace with a standard, or gtr or something other than the nismo one :)
then id add eye lids and replace the wing :( ((( to me the r34 just doesnt look the same from behind without the wing IMO)))
still awesome car, keep it up :huh:
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
