Took a few pics yesterday of this beast :O
What a beautiful car!! The photo shoot was a spur of the moment thing.
No sun when we arrived, then the sun came out of know where and then it started to rain.
Then my lens got a little wet and photos came blured, as i didnt have my cleaning kit..
To top it off my brand new circ. polarizing filter broke the day before :)
Im no professional and far from it - just thought i add that line in hahahahh
oh still stock kit lens ;)
Anyways here are some shots:
Edited by siddr20
nice stuff!!!.. white is a biatch to get right. use a flash in daylight to get the wheels to pop a bit more then you can soften the exposure so it doesnt blow out.
I know :P
If i wasnt going to europe in two weeks i would have had a better lens and few external flashes by now..
but all i got is just a body and stock kit lens :)
one day sigh.. hahah
Edited by siddr20
Aww dodgy fake motion blur Sid, Your better than that :P
lovely looking car though
I know.. i just had to do it.. it was distracting me soo much!!
i think thats gt-r's for sale around 65k??
very nice pics btw.
Yup its for sale if anyone is keen :)
very clean car!!
Nice pics. And don't knock the nifty fifty it's a great little lens...
Yeah I noticed the dodge motion blur too... 1/640th of a second doesn't allow much motion blur :D
Regardless, they're nice pics...wouldn't mind gettin my hands on some high res copies...
hahahha i know :P
The background was distracting me quite a lot :(
oh i love me 50mm lens and im by no means knocking it..
I think its really a good time i move on from the stock 18-55mm lens.. Its good, but i need something better now!!
Edited by siddr20
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
