Cheers mate,
yea that's right was bought over very early, practically as new I believe with very little kms in japan.
got the wheels on yesterday, and I could not be happier with the result, looks perfect IMO.
Will try take some pics this afternoon and post here.
Cheers
Anthony
Cheers mate,
Cheers
Anthony
Unreal.. Man the day I put my TE37's on my car I went home washed it and I was so pleased.
Can't wait to see the pics.
Some photos I took while at the SAUVic Show 'n Shine today.
IMG_6512 by aaronactive.net, on Flickr
IMG_6504 by aaronactive.net, on Flickr
IMG_6498 by aaronactive.net, on Flickr
IMG_6492 by aaronactive.net, on Flickr
IMG_6408 by aaronactive.net, on Flickr
IMG_6336 by aaronactive.net, on Flickr
IMG_6393 by aaronactive.net, on Flickr
IMG_6392 by aaronactive.net, on Flickr
IMG_6379 by aaronactive.net, on Flickr
IMG_6426 by aaronactive.net, on Flickr
IMG_6343 by aaronactive.net, on Flickr
Wow, great shots. A real Nür fest in here at the moment! :wub:
Looks like a great venue for the Vic SnS. Love the bronze CE28Ns on the Jade Nur.
Nice car Huy! The juxtaposition of the GTR and Sierra brings back memories of '92 :rolleyes: even if it is the wrong generation skyline :)
Always loved your car Matty. Really like that custom colour. :thumbsup:
Dan - looks tough mate. That first shot is interesting, really shows the difference in front overhang and where the front axle is relative to the scuttle on the Skyline vs. the Lancer
I reckon. Lots of Nur's popping up! Great shots, Evade. All of those cars looks awesome.
Just out of curiousity; I thought p-plater's can't drive turbocharged cars over east? (they can in WA)
Yeah we're not allowed to here either, not sure what the story was with that!
The owner knows and does not care from what I gather.
So many GTR's! Hopefully getting mine after I sell my current car in a couple of months :)
...hope you do too David!
We know you like to take care of your car! > and your lovely G/F > in that order - lol
Wow at the R34 pics over the past 2 pages.
There should be a warning saying this thread is no longer work safe.
HARD HAT AREA!!!!
lol
Haha lets hope she doesnt read this!
She will - she will!!!
But I'm the one in trouble (-not you) > just hold her back to protect me; that's all!
Heres some quick pics of my car with the new wheels, couldnt vennture too far from the house today due to very average looking weather...
Still sitting too high, especially at the front but a huge improvement imo...
Along way to go to get it how i want but a very good start with these wheels!
Cheers,
Anthony
Cheers,
Anthony
Looks fantastic Anthony, set of coil overs and a front diffuser - you'll be set!
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
