Now what's the procedure > which buttons do I need to push to convert the above 2D picture into 3D physical form 3.5mX1.8m ???
There must be a way !!!
Oh wait...
Let me take this keyboard down to the garage first...
...and the rest...
Marko, the size is 18x10.5 +15
I believe that they come out of the factory with normal GT-R (BBS) rims, although the original owner immediately optioned up to BBS LM whilst new.
My log book also says (& I'm proud of that owner for this), that all services were done with Nissan Japan (which doesn't take kindly to their cars being serviced elsewhere I've been told).
I consider myself fortunate.
Many thanks as usual Michael & my Victorian friend- appreciated.
Since the philosophy of the N1 was to keep the car light, I've done a few things to lighten up the car even more with titanium goodies.
Considering a C/F prop shaft soon > still won't be as light as your bike tho'
I remember in the 70s how there was massive competition between the Kawa & Yammy > I used to play golf with the Sales Mngr of Yamaha Aust > he asked me if I wanted one hehe...
Looks great Terry.
I should have picked up that Titanium strut brace in the for sale section.
Anyone in Brisbane have a Nismo air intake?
I want to see if it will fit over my radiator and have enough clearance for the bonne to close :)
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
