We actually know another Steve, of Steve's Auto Barn at blackheath; he owns a BB with white LMGT4s and plates ORSUM. Great looking car, but been ages since Ive seen it.
Here it is!
And here's Chris's. Yeah it's nice. :)
Edited by God_speed
Maclarenf1, As promised. Only had two more pics -
Will have them one day once the engine side is sorted....
Silver LMGT4 looks really nice on a Black R34 GTR with Nismo Skirts and Spats with VS-2 bonnet. (not huge fan of the Nismo bonnet mind you)
This has being my inspiration for few years, which led to me buying my car... Not quite there yet !!!..
^ That looks very similar to God_Speed's car. Fantastic.
Maclarenf1, I'm assuming your car is black. Do you have any pics of it as is?
Pretty standard V-Spec [had a V-spec 2 badge, first thing to come off :) - hate fake badges] - had it for about 1.5 years now, ideally want to do around 1 track day maybe 3 month or so..once the engine is up to that, will think about the exterior...
Runs HKS-Fcon Vpro currently with Stage 1 mods (Only Turbo's to do - getting GT-SS / -9 at the end of the year and she is done)
Also came with some odd bits from japan too like 4 wheel drive controller, modified Diffs, heavy clutch, camber arms, oil cooler, NOT normal FINS on the rear diffuser and a mother of strut bar :)
Currently Runs 239.9 AWKW with 1 Bar + Cam gears on high and stock boost on Low (HKS EBC).
http://imageshack.us/photo/my-images/193/qldraceway.jpg/
http://img844.imageshack.us/img844/313/img1591n.jpg
http://img34.imageshack.us/img34/9316/img1554sd.jpg
Very Envious of you'r car - i am not very good in washing or buffing IMO...
http://imageshack.us...qldraceway.jpg/
http://img844.images...13/img1591n.jpg
http://img34.imagesh...6/img1554sd.jpg
Looks fantastic maclarenf1, thanks for sharing.
Thanks for the kind words. I'm no pro, but if you ever think I may be able to help with some buffing tips - just give me a yell.
M-spec inspired seats sound good, black leather i assume.
Very Nice!
...and some person is privileged to have both VS2 & R-Tune bonnets...
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
