I like lowered cars but for me, that is a bit too low
Agreed.
Love to look - not to own.
you guys serious?
i dont know why more than 70% of 34 gtr owners are against lowering, and if "twisties" are your excuse pfft
R34 GTR's can run pretty aggressive. I know a person running 19x11 +6 F and +3 R, 275/30/19 all round but no scrubbing.
The car is low too!
Could be possible.
Would have to be rolled at the very least and a bit of camber.
Pics?
I'm running 19x10.5 +12 GT-Vs now for a change and have 15mm spacers on.
So thats an offset of about -3mm. I could theoretically run another half inch on the inside with this offset.
I want some 18x11 +5 or -5 and dial in :)
My cars not really what you call proper though. Slightly wider than real R34s.
what sort of width and offset would I need to run to fill the guards like on that blue 34 GTR ^^ up there, on my 34 GTT?
Sinno might be able to help you and other R34 GTT owners.
Sinno was running crazy offsets for a GTT if i recall correctly.
you guys serious?
I hope I didn't offend u. You have a great car and BB is my favourite colour for the 34 (inline with a white n1 :) aka Terry's car)
Not everyone liked my r34 wheels on my r32 so u can't make everyone happy.
I have this thing with the wrx, evo or gtr cannot sit too low...can I explain it? No hahaha
nah all good fellas
just if you compare 2 gtr's identical side by side, 1 slapped, 1 jacked up . then youll see how phat it looks
something about guard over tread makes the biggest difference to side profile
when i first lowered my car my mechanic couldnt fit the straps under the car and had to raise it 20mm
i asked if thats ever happened before, he said no
I AM BOSS haha :D
Wouldn't say crazy offset, but good enough stance to still make it practical.
I'm running R: 18x10+22 245/40 and F: 18x9+15 235/40.
Note: Its not chrome lol. just very clean!
I'm pretty sure Shinobi_s14 is running tougher offset?
Any scraping issues with this setup or did you just roll/lip the guards?
Yeah SiNNO I've got 18x9.5 +20 on the fronts 225/40 and 18x10 +15 rears, 235/40, just had to roll the guards, thinking about flaring them a tad in the future though but it tucks in real nicely when it's lowered with bit of tyre tuck but had to raise it a tad due to the monster driveway at my place haha
Edited by shinobi_s14
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
