I like lowered cars but for me, that is a bit too low
Agreed.
Love to look - not to own.
you guys serious?
i dont know why more than 70% of 34 gtr owners are against lowering, and if "twisties" are your excuse pfft
R34 GTR's can run pretty aggressive. I know a person running 19x11 +6 F and +3 R, 275/30/19 all round but no scrubbing.
The car is low too!
Could be possible.
Would have to be rolled at the very least and a bit of camber.
Pics?
I'm running 19x10.5 +12 GT-Vs now for a change and have 15mm spacers on.
So thats an offset of about -3mm. I could theoretically run another half inch on the inside with this offset.
I want some 18x11 +5 or -5 and dial in :)
My cars not really what you call proper though. Slightly wider than real R34s.
what sort of width and offset would I need to run to fill the guards like on that blue 34 GTR ^^ up there, on my 34 GTT?
Sinno might be able to help you and other R34 GTT owners.
Sinno was running crazy offsets for a GTT if i recall correctly.
you guys serious?
I hope I didn't offend u. You have a great car and BB is my favourite colour for the 34 (inline with a white n1 :) aka Terry's car)
Not everyone liked my r34 wheels on my r32 so u can't make everyone happy.
I have this thing with the wrx, evo or gtr cannot sit too low...can I explain it? No hahaha
nah all good fellas
just if you compare 2 gtr's identical side by side, 1 slapped, 1 jacked up . then youll see how phat it looks
something about guard over tread makes the biggest difference to side profile
when i first lowered my car my mechanic couldnt fit the straps under the car and had to raise it 20mm
i asked if thats ever happened before, he said no
I AM BOSS haha :D
Wouldn't say crazy offset, but good enough stance to still make it practical.
I'm running R: 18x10+22 245/40 and F: 18x9+15 235/40.
Note: Its not chrome lol. just very clean!
I'm pretty sure Shinobi_s14 is running tougher offset?
Any scraping issues with this setup or did you just roll/lip the guards?
Yeah SiNNO I've got 18x9.5 +20 on the fronts 225/40 and 18x10 +15 rears, 235/40, just had to roll the guards, thinking about flaring them a tad in the future though but it tucks in real nicely when it's lowered with bit of tyre tuck but had to raise it a tad due to the monster driveway at my place haha
Edited by shinobi_s14
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
