Friday Night Mountain Run - January
We play networked tetris but I've discovered open ports (shhhhh) which allow me to play CO (conquer online) and the other day a work mate was playing EU...whatever that is :(
well ya don't so :P
theres always the report button :O
  • Replies 281
Posted Images
Guys, me and shane installed a new aircon compressor on my car last night and we didnt do something back up right, I have a massive boost leak, me car currently runs 0.2 BAR... Oh and a fully hectic boost-leak sound when you try and accelerate.
I best be finding that. If anyone wants to come help itd be much appreciated, im on the northside, my mob is 0400 813 419
Sorry man but I got a few things to do this evening before we cruise :P Not that I'd be much help anyway. Hope you get it sussed out in time :O
guess I am out of this one, can't beat the heat in my no air-con 32 all the way to the coast.....
you guys have fun & stay safe, cheers!
try winding the windows down? it wont be that hot tonight. prob low 20's so should be perfect weather for it!
RYN26 itll be night? I dont see the problem?
I dont have aircon in my 32 either... or boost atm for that matter, but im working on both of them :P
check all your clamps......
suggestion from marc....
are you serious?? i have a/c but wont be using it
sorry to hear! im stuck at work till 5 and then have to train it to cleveland - hope you find it!! (i have a spare IC clamp i can bring along! - think its 3.5")
Edit: almost forgot!!!! 3hrs and 35mins to go!!!!!!!
Edited by ZENNON
I increased the booking to 30+ people, its all good.
But my car is in a bad way, I dont know whats going to happen...
It wont hold idle now and is hunting through the lower RPM, same thing that happens when u dont have a AFM plugged in but they are plugged in...
sorry 2 be so late im in too 2 seats all so for HB and put up the onfo agen of what times and place's please ian thanks...
check the very first page guys. all on there for you.
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
