  • Replies 376
Posted Images
LMAO!!!! sorry! its what came to mind! and i've decided against taking the longer way around! its not twisty enough to make it worth it! :nuke:
and woootttt jago! :stupid: should i put you on the for sure list?:stupid:
dunno, depends :laugh: if not, pm STRETCH and abuse him :laugh: he has my engines :laugh:
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
