[30/12/06] ! Last Cruise Of 2006 ! [30/12/06]
Feel sorry for a couple of guys at springwood meetup who's night maybe an expensive one with tickets been dished out, usual crap with cops rocking up as i saw whilst driving past in missus car then past 10 mins later as the cops ushered most of them off but the remainder that were parked there undercover car and cops dishing out the tickets
eh hope you all had fun
EXACTLY why I dont go on boostloosing / cockheads brisane cruises....
I hope no SAU'er got busted.
IanB...I assume you mean Boost Cruising and Cruising Brisbane, if so, perhaps not best to rag out an entire forum online. I am sure there are many decent people on their forums. I would like to think they don't rag out SAU in its entirety on their forums.
Cheers,
MrBenno.
Thanks for everyone who came out tonight, was an awesome turnout didn't think it'd be so big but thanks to you all there was about 150 cars at Springwood Crazy Clark's.
Pitty some people had to do a runner from Springwood, we had one undercover cop car roll in and wanted to start defecting people.
Did he get anyone from here? I know he got the black skyline with the big wing for a BOV and dark tint.
Anyways, it was good to check out the cars at Springwood, dam there were some nice rides there!
The drive to BWCP wasn't too bad just so many cars it was hard to keep together but none the less it was awesome didn't have too many dickheads which was good ..always one on every cruise though.
Once we got into BWCP within 10mins we were there the place was packed it would of even been hard to find a car park it was that big of a turnout.
I guess once we got to BWCP we all broke up cause we couldn't all park together I walked around though trying to remember faces and have a chat to you all.
A few people came to the Coolangatta Meet, but it was in patches etc, but there was a few cars there but like I said after so many broke up at BWCP we weren't going to get all the cars together again.
Police wern't too bad tonight I think, I guess once the cops at Springwood knew what was going on they would have told the cops down the coast.
No one else got done here did they? Hope not!
Anyway, thanks again for everyone who came, 150 cars was an awesome turnout!
Have a happy new year, and stay safe! :P
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
