*** HURRY LAST DAYS ***
DBA 4000 info
Please post if you're interested in going ahead with these. I've closed the other thread to keep it simple. :P
R32 GTS-T
Front DBA 4909: $200.20/disc save $49.80 per disc!
R33 GTS25t
Front DBA 4963: $209.00/disc save $88.00 per disc! Rear DBA4908: $200.20/disc save $49.80 per disc!
All prices are per disc and include GST.
On a 33 this is saving of $176 for the fronts,
or $275.60 for front and rear.
The discs are being purchased through Gavsport at St Marys. Contact Kevin on 9673 0988 or [email protected] and tell them you want to be in the group buy Dino set up for Skylines Australia. Go to post all in RED on 2nd page of this thread for more details.
Fitting cost at Gavsport(approx.):
Front only $66, Front and rear $99.
They will also organise a group fitting if there are enough of you which would cut the fitting cost even more. I think around 5 or 6 would probably make it worth while. Probably cut the fitting cost by 20%.
Who's interested? :D
  • Replies 79
Will these guys post to Brisbane or is this offer only for Sydney people? I was in Sydney for Easter but don't plan to go back there for a couple of months. Might be able to get a friend to pickup but would rather frieght it up here.
heh sorry Brody couldn't resist...:) I'm not sure about 3 or 4 weeks, if you give a deposit I'm sure that would work.
jlnewton, the more people the better. I guess they would freight them up to QLD. Let me check.
Well Discpads.com will send 5 rotors anywhere in Australia for $40 so as long as its around there I am happy. Besides, who can wait? As soon as I buy something I want to fit. Everything must stop until they are fitted! I have had numerous things sent from UAS, Just Jap, JMS and Takas and it has always been reasonable.
Hi,
This is off the topic, but can someone help? I would like to know what the diameter of R32 GTSt, R32 GTR and R33 GTSt disc are in diameter. I have noticed that R33 brakes are becoming a popular upgrade for an R32 - I thought they were the same.
Any help would be great!
Thanks.
Retail is:
R33 Front DBA 4963 $297.00/Disc Rear DBA 4908 $250/Disc
R32 Front DBA 4909 $250/Disc
So on the 33 fronts you will save $88.00 per disc!
A saving of $176 for the fronts,
DBA have given Gavsport a great deal on these as well so you won't do better if you can get "trade" elsewhere.
Who's in? :D
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
    • Hey mate, really appreciate the help. Have been looking pretty extensively myself and was certain they were retro fitted, but then ended up finding a 4 door with what looks like the same side skirts or at least the closest I’ve seen. The photos from the Offset Kings event at Sunrise 2016. https://fatlace.com/offset-kings-okayama-at-sunrise/
