Hey guys,
just got our new Trust Drag intercooler from CRD(thanks guys).
Its the biggest one that you can buy off the shelf.
its 710mm wide X 305mm high X a massive 165mm thick(150mm tube).
I'll be putting the cooler on this weekend, if CRD have time i'll get a power run on the sat morning then fit the cooler and then another one once the shop opens back up.
maybe even try and rerun on the sat.(fit on the friday night).
Once the cooler is fitted i can then rule out any pressure drop across the core.
I'm thinking that once this cooler is on and the 4" exhaust is back on the 700cc injectors will impose a power restriction.
CRD have said they normally see them max out at around 500-520 awkw. I'll be glade if our set-up can make that sort of power with the 33d that we have.
I know that with the 4" exhaust n the car will come on boost earlier and i should see the 500 at about 8000rpm.Since there should be no restriction up top the only thing stopping power all the way to its 8500rpm limiter would be the turbo it self.
The set-up now on the GTR is a TRUST exhaust manifold SARD wastegate, TRUST T88-33D, TRUST 710 X 305 X 165 intercooler. 4"piping to a HYPERTUNE intake manifold and HYPERTUNE 100mm TB.
The head is also ported.The cams are only the tomei 260 9.15 pon units, bu ti think they will work well with the small exhaust housing.
I'll let you all know how the new set-up goes and back to back them with our old GT-SS set-up.
Cheers
https://www.sau.com.au/forums/topic/148001-just-got-our-new-trust-drag-cooler/
I Have to take some photos and take them around to dough boy to put up how about i just give him the photos of the intercoolers and the dyno tuns on sat as i'vce just booked the car in for a power run at C&V at 7.30 on sat morning wich should give the guys at Hypertune enough time to install the cooler to a stage where i can drive the car around for the after power run.
Cheers
    • We used Knox Drive shafts years ago when we were doing gravel rally, good guy but I heard it had changed hands? He's got a lot of stuff and is miles cheaper than GJ and so on. He used to have a lathe setup with a MIG torch on the tool holder so he could get the uni welds just right, quite a clever guy. I just got a driveshaft done for my sequential installation and that was through Balancing Services Australia in Preston, they did the Gibson cars in the old days. New genuine CV's, billet yoke, new centre bearing and chome moly shaft was $2k.
    • Thanks for sharing that mate, I've got a couple of spares on the shelf but all the unis are tight....will give old mate a shout. BTW are you sure it wasn't just a $400 paint job? Any detail of what they replaced (cut/reweld?)
    • Yeah I saw that about the US Q50 recently, apparently it was shown to Inifiniti dealers (probably to help with their depression about the cars they can sell). Seemed like a really obvious step to me, the platforms are very similar in many ways. Even if there aren't many people who actually put the money up it should really help with image/reputation. What hasn't been clear anywhere if that is a V38 model of if they are just going to add the trans as an option in a new model year. What they did with the Z from 370z to "Z" is just weird so I'd be surprised if they released this as a V38. Great news for me to have an option; it is far from confirmed that I can get any decent track sessions through the auto so having a manual I can swap to is great.
    • I ordered it this morning, I'll disassemble it post pic's and info following delivery.
