hey guys..
looks like ive found a buyer for my car and just wondering what sort of things are picked on for an rwc?
my car isnt big on the mods so all that stuff 'should' be ok..
pod filter, exhaust (that isnt too loud at all), not low etc
will they pick on things like the SAFC, turbo timer, boost bleed valve etc
my car isnt bodgy and im not looking for some backyard operation, but does anyone recommend any places in the box hill/doncaster area to get it done?
cheers in advance
james
https://www.sau.com.au/forums/topic/148286-rwc/
most places wont pick up on boost controller, safc. Turbo timer is legal, it's not being in your car while it is running that is illegal.
They will omly pick you on exhaust if it is really loud, they wont measure the db or anything. Most places will get you for oiled pod or pod not secure, but only some will get you for having pod + cooler.
They will all usually measure height.
Then you have the other normal things, all lights in operation, safety devices like seatbelts etc, tyre tread, window screen cracks, brake pads etc
https://www.sau.com.au/forums/topic/148286-rwc/#findComment-2767566
  • 3 weeks later...
racing project in thornton street does RWC, just off rooks road right near kamakazee motors and his into imports
try there, ask for nelson... good bloke
ive done a search but havent come up with much, can anyone recommend a place in the boxhill/doncaster/nunawading type area?
im back briefy from o/s so need to get this done in the next week so the car can be sold
Edited by Ricos
https://www.sau.com.au/forums/topic/148286-rwc/#findComment-2809411
A turbo timer is not an approved modification.
It is illegal, whether you sit in the car or not.
Agreed.
Well if you are sitting in your car, then they can't tell the differance between the tt being on or your keys in the ignition :glare:.
It's never been legal; but i have never been pulled up on it, nor have i heard of anyone ever being pulled up on it.
https://www.sau.com.au/forums/topic/148286-rwc/#findComment-2811322
my tt isnt actually functional atm anyway, its not wired up into the new alarm so that shouldnt be a problem
il give the guys at racing project a bell tomoro
any others?
If it is not wired up/working just unplug it and remove the unit for the rwc.
https://www.sau.com.au/forums/topic/148286-rwc/#findComment-2814204
    • Let large companies that are making money off selling kits do the preliminary engineering for you. If they all do -10, then that is all you'll ever need.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
