  • Replies 6k
Posted Images
id be more than happy to do that. with the previous cruise, thats why i did - went crusing in the hills in the missus celica and worked out what roads were nice and so worth. end result was what we eventually cruised on which everyone seemed to like.
Yeh that was my car, but not too sure if it was me sitting behind the table, Tall with blonde hair?
cant remember, its been some time now but im sure the stand was promoting the products you had in your sig.
rofl @ the looking so sad comment. mines in the shed with a faulty starter motor i suspect. so im going to sort that out before i drive it again plus it ran out of rego the saturday that went by which co-incidently was also when the car started to play up (bad luck and timing i guess).
No i don't have any thing in there yet, prob only go for the Cradle bushes, As i already have Cusco Strut bracing, I might go a Steering bush.
Christian Pickering has had the strut bracing in at the G1 event and claimed it was stiffer than Viagera, and Kelly McKinnon and James Mardle runs his stuff also. The product is made from Aircraft Billet Alluminum and is strong as, and is HEAPS light, can't believe how light some of that stuff is. Did you check it out at Mallala?
upgrade to what chillam? im assuming your talking bout cars btw
no, loyal to the origens of twin cam RB... the 20!
But, goodies included in upgarde:
RB25 series 1 turbo
SAFC2
Remove inlet butterflies on inlet plenum
Fix busted studs on exhuast manifold
Rebuild clutch cylinder
Full Serive and Dyno tune
I cant wait to see the dyno sheet!
I go out for the night and there are hundreds of pages to read!!! you guys are hilarious.
RB25 series 1 turbo
SAFC2
remeber to post the result here with dyno sheet ;)
    • Hello everyone, I'm glad to join you.
    • Definitely do-able haha. I will give it a try if the fuel pump hanger does not solve the issue. Just need to find some quiet time in the area, Malta is like a big city and I live right next to the main hospital so it is very busy during the day. I'll be installing it in about 2 weeks, found a garage that is pretty knowledgeable and has the necessary tools. This garage has worked on multiple builds, even for competitions. They even asked me to stay with, so I should be fine.
    • Just to add, I found the r32 gtr ecu the most forgiving, the r33 one would get the shits.
    • For what it’s worth I drove my gtr for over a decade with gt-ss as a true daily after I pulled off the -5s, I had it engineered and went with stock ecu etc.  never skipped a beat.    I would only worry if you can’t get good fuel all the time in a tropical paradise
    • I bought an engine from a friend of a friend many years ago, it was sold to me as a RB25det Neo.    recently I started pulling it apart and noticed that the intake manifold was pretty different from others that I had seen on RB engines so did a bit of research and found that it was a non turbo manifold. So I’m sceptical now that it is a NEO DET and just thinking it’s a NEO DE (it does have a turbo strapped to it currently).    can you identify the engine model from the numbers on the block?
