  • Replies 6k
Posted Images
BP98 here is $1.42 here ;)
Thats because you guys are so far away from anything, and out of the loop.........lol, Just jokes petepie, the old boy lives over there somewhere......not sure where exactly, but those prices are shvthouse, haven't seen them that high here, YET!!!!
