  • Replies 6k
Posted Images
180 had an exhast leak that i just couldnt block using simple gasket glue/paste so i welded the damn leak up. mig welder. just had some shut eye as i cant seem to open them for long before, obviously better now since i can type properly.
lol
gotta be carefull to never look at the flame, ive only had it happen once and i think it was at tafe, but it gave me a killer headache
yeah darren, ive been thinking and come to the conclusion that having two cars - not to mention my bros 32, to take care of isnt a good idea. thinking (when its sold) get a scooter as a daily and use the rest of the money on more beneficial purposes.
hey sam, i guess you "may" be the last person to drive it before it gets sold. unless of course i still have it by the boostworx dyno day :P
will have to google and see what a vespa looks like, ive heard of it though.
this has 49cc. is that fast in terms of being able to sustain a certain speed for a period of time ie 60km/h? My boss has two mini choppers but i dont know its capacity, they were weak and only good fun for a short period of time until the electric starter fooked up.
Oh look i think those choppers are 49cc, but the motors in a 50cc proper scooter are much better, the Vespa is a old school scooter heaps better.
My mate might wanna sell his, It's a Vespa 50 Special, came with a 50cc and he has made it into a 112cc with some nice Italian mods to it. Goes hard as, has beaten a 12A 808 before. Not sure how much he wants for it but could be quite expensive with the mods he's done, You might be looking at something a bit cheaper.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
