  • Replies 6k
Posted Images
yeah im good mate.
QUESTION:
I did my spark plugs on my car coz it missed and sounded a bit like a rotor at idle, now its real crackly, like its breaking up, i dont know wat the f**ks going on. After a few minutes at idle it turs off?? but when you rev it and drive it its ok,
yeah drugs are good.. :D
i dont know mate. gapped the wAy they came.. it looked the same as the ones that came out.
it was a rough idle before, now revs smother but rougher idle...
they are 1mm so 0.8 you rekon?
Edited by DriftR_33
    • Hello everyone, I'm glad to join you.
    • Definitely do-able haha. I will give it a try if the fuel pump hanger does not solve the issue. Just need to find some quiet time in the area, Malta is like a big city and I live right next to the main hospital so it is very busy during the day. I'll be installing it in about 2 weeks, found a garage that is pretty knowledgeable and has the necessary tools. This garage has worked on multiple builds, even for competitions. They even asked me to stay with, so I should be fine.
    • Just to add, I found the r32 gtr ecu the most forgiving, the r33 one would get the shits.
    • For what it’s worth I drove my gtr for over a decade with gt-ss as a true daily after I pulled off the -5s, I had it engineered and went with stock ecu etc.  never skipped a beat.    I would only worry if you can’t get good fuel all the time in a tropical paradise
    • I bought an engine from a friend of a friend many years ago, it was sold to me as a RB25det Neo.    recently I started pulling it apart and noticed that the intake manifold was pretty different from others that I had seen on RB engines so did a bit of research and found that it was a non turbo manifold. So I’m sceptical now that it is a NEO DET and just thinking it’s a NEO DE (it does have a turbo strapped to it currently).    can you identify the engine model from the numbers on the block?
