  • Replies 6k
Posted Images
LOL !!
I heard Greenline were better, cheaper shipping etc. hahah, anyways got the kneecap in a jar at home, so I can unzip the leg and whack it back in (like false teeth) as I see fit... NOT.
Yeah, a tad sore now. Pill'd up but rather not take those mindbending painkillers (certainly not at work anyways). Meh. And I was going so well with the physio as well, had increased the strength of the muscles around the right knee area by over 40%.
Simply lifted left leg up and lunged to stop a ball that was kicked to me, and the weight transfer and angle on the bad leg just caused it to horribly collapse in on top of itself. Meh, I'll get used to it. Apparently its partnparcel of not having the kneecap.
LOL !!
Dude.... I got coolant poisoning from some Castrol Radi-cool at the moment and the part about no kneecap and the thought of the pain you have to go through really is making me consider inducing vomiting cause I feel like ultra-shit now. I woke up last night at 4am to find my mouth completely numb then when I read the bottle it said I shouldnt drink it? WTF? lol...
lmao.. sorry I had to laugh.
I've had coolant in my mouth before and the taste is unbelievably horrible. Nothing I did got rid of the taste that hung around all day. :D
How you ended up drinking coolant.. lol do tell us. :(
I can't remember the last time I owned a brush/comb!
:P:nuke:
my leg collapsed in on itself 2 days ago.
so sad
so PAINFUL gggrrrrrrr
tibia went out and femur came in (no kneecap), fullon collpsed into itself
ouchies
:O
:D FAR OUT!!!!
Sounds horrible hope myou are ok and get better soon
By the way I have arrived in Adelaide today :(
:P:nuke:
:D FAR OUT!!!!
cheers man, hope you enjoy wetnwindy lil'ol Adelaide, today is normal - it always rains here
I haven't brushed my hair for a good..... 8yrs I'd say.
Shaved head. :(
Shaved head is cool
I know all about Adelaide use to live here that why I moved to sydney lol
Jess
I've had coolant in my mouth before and the taste is unbelievably horrible. Nothing I did got rid of the taste that hung around all day. :nuke:
Long story short, water cooled pc, curiosity, fumes in my room, numb mouth at 4am in the morning, thought I was gonna die. (I had to syphon the shit out of my tubes).
Edited by Pauly33GTS-t
welcome Jess
sorry to hear about your knee Brendan ... were u on pain killers when u put all the thermal paste on the CPU :D
Yeh always puts on a great show for visitors!
YAY!!!
The regulars are here :nuke:
Yeah im used to crappy weather especially when we come to visit :( but will still have fun :P
Hopefully I can wish the rain away :sorcerer:
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
