  • Replies 6k
Posted Images
hahah... while were on the topic of old ladies.....
I pulling out of Castle Plaza Edwardstown when this old bag in her white bloomers and bra walked out in front of the car all frantic.. I thought WTF maybe her hubby's crook or something and needs a phone so I opened my window slightly and she farking asked for a smoke.. lmao.. I couldn't believe the crazy old bag.
Were sorry Paul....
Ok... EVERYONE.. No more ripping on Paul. He doesn't like it..... OK?
That "ok?" is still giving us the option right??? ;)
no its ok cubes, u can rip on me ur a wog. darren... u can go to hell my friend.
Pfffft going there anyways champ........LOL Just when and how is my question!!!
