Hi!
I've had a 3x2bolt axle r180 diff in my cefiro. I went to a local wreker and they had a whole rear subframe, which they said is from cefiro. I bought it.
It was a R200 diff (5X1 bolt axles) with bigger stabilizer bar. Thicker than my old one by about 1cm o so. So I bought it. I thought it was a normal open diff and stuff. Cause we couldn't turn the wheels, because one of the calipers was jammed.
Today we bolted the new R200 and 5x1 bolt axles to my old subframe and installed everything. Went for a spin. It was much more better at doing donuts than open diff LOL. Then we went to test it on the highway. The car wasn't stable and it had those really nasty sounds when I was accelerating.
Those weren't clicking, more aggressive. Pretty scary :)
Anyway, we came back, changed the tires, cause my right tire was really bad cause of the open diff madness the other day. So stability was there, when I accelerated everything was fine no scary sounds. The sounds appeared in those slow turns. When I came on gas it was like something jamming in the back and those loud and scary clanking-clicking sounds. The car was vibrating a bit while turning. When I disengaged the clutch the sounds disappeared. It seems they only come when I accelerate while turning in those low speed corners. I assume I got some kind of 1-way diff, since it locks up on acceleration. And if its from cefiro, as the guys said. (could be some other rwd nissan ?)
Did some of you experience same kind of stuff in your cars ? People use lockers, 2-way diffs here. Do they behave in the same way, like in my case ? )
And what could be the problem ? Wrong oil ?(we used shell gear oil). Not enough oil ?(We added oil untill we saw it through the the little hole.)
Please advise me on my little problem. It's really annoying, when the car is rattling and stuff.
Thanks in advance !
P.S.
Mark on the final gear : 46:12, does it mean something ?)) Good for me or bad ? LOL
Below is my original rear subframe, the new R200 subframe i got with some wicked diff.
Edited by robots
Maybe I put it wrong :P
When I'm in neutral it doesn't clunk, when in gear with clutch disengaged it doesn't clunk. It only does that when I accelerate. So it's 1 way, i think.
I just don't think it should make that loud noise and rattle the car so much. Its stock lsd, so it's pretty strange to me.
Cheers !
Maybe I put it wrong :)
Cheers !
there are no R200 1 ways... no such thing.
a Two way lsd will clunk when loaded up, that means accel on sharp turns if you back off and coast through or in neutral. it wont load the clutch plates up enough to lock them, so no clunking.
perfectally normal behavior for a 2 way.
Thanks!
Actually it clunks when Iback of the throttle and coast in neutral through very tight turns (parking lot). And car jerks, when outside wheel can't keep up with the inside.
I will take a proper look next weekends.
I think its to tight ).
Will post up some pics then.
Edited by robots
also just to be sure check U-joints and mount bushings. and make sure everything is tightend. dont forget your LUGNUTS... yeah i know stupid but i have made the mistake of forgeting to retighten the lugnuts after a few miles and i thought it was my diff but the wheel was just falling off haha...
ibve done that also... several times now :nyaanyaa:
but yeah, the diff prob is tight, however rest assured its a good thing, and on higher speed corners etc ect it will be an awesome thing.
So put up with some low speed jerkyness for some high speed fun :laugh:
Sounds like a mechanical 1.5 or 2 way.
They best way to test is A) Look at the diff centre and check for a shape like this:
<> = Will equal a 2way
You'll find what im talking about in the centre of this photo, its hard to see in the pic but its through the "holes" in the centre that the crown gear wraps around.
Alternatively, when moving into a corner at reasonbly high revs say 4-5k, back the gas right off which will cause alot of negative torque through the drive. If the car shudders, its because the inside wheel is slowing due to the neg torque from the motor and the outside cornering wheel is being forced to slow by the diff locking it momentarily.
This is what a 2 way is designed for in the case of coming off the gas really quickly rather than just one wheel locking and unbalancing the car both with lock in a 2 way.
Thats why drifters can "lift off" drift with alot more control with a 2 way LSD just by coming off the throttle at the right time.
Oh yeah, The reason if your in neutral, or on the clutch its quiet is mechanical LSD's are all based on torque, no torque no action = quiet.
I sometimes find when I put a new centre in I just have to put the clutch right in to make tight turns, or when taking off while turning such as out of a street just control the torque with the clutch afterall thats what its there for.
Its kinda hard to explain and I am hungover, but I hope this helps :P
Edited by BasketCase
  • 3 weeks later...
Hey, guys !
Can I use Motul 75W90 Gear Oil or Redline High Performance Gear Oil 75W90(I think this one contains additives for lsd).
What should I put in ?
Any other options ?
How much oil should I put in ? 1L ?
Thanks !
Use Penrite Limslip diff oil, 85W-140. Very quiet and very cheap. $24 for 2.5L.
Your diff will take about 1.5L, probably a bit more
Edited by salad
Can you recommend something else ? :) I don't think I can find it in China( I was just able to find those 2. Could they work ? Could any other 85W-140 work ? 76 maybe ? )
Or any other brand ?
Edited by robots
I've took the thing out on weekends. Didn't find any sings of tear or wear.
Added 85W-140 Valvoline gear oil. It said, that you could use that oil with limited slip diffs. So here are the pics.
I guess my one is 1way or 1.5 way.
according to cusco:i-33.jpg
Anyway. Its still noisy and the car rattles. A little less then before though.
It could be backlash? If the diff is in the car... lift the car up on stands, put it in gear, take the handbrake off, climb under the car, see how much you can rotate the wheel/halfshaft before the input shaft/tailshaft rotates. If there is excessive slop between the input shaft and the crownwheel it will make noise and could chew out your crownwheel.
    • Before starting any work, we attempted to adjust the tune. However even after adjusting it to certain extremes like completely stopping fuel, it had no effect. What fixed it was removing the Nistune Board and installing the original EPROM instead. This immediately fixed the issue. Everything should have been fine with the Nistune Board installation, so I am unsure why it has caused a problem. The soldered connector is also properly soldered. This worked when I first got the 550cc injectors, before cleaning, but that may have been a coincidence.  We ended up not installing the fuel pump hanger (at least for now). So currently running stock injectors, stock fuel pump, stock fuel pump hanger – Well everything stock except the exhaust. Now I have around €1400 in Nistune, Injectors, and Hanger collecting dust for the time being, perhaps I'll install them in the future. For now I'll enjoy the car as is 😁 Thanks a lot for all your assistance, I really appreciate all the help you have given me.
    • The turbo can’t be the issue. They’re proven to make much much power than you’re making. There is something in the setup that isn’t correct. - has the exhaust got any silly step downs? - what exhaust manifold?
    • Ok, just the way you wrote it made it look like you had the stagger the wrong way around
    • I was getting anxious with the DVLA not knowing if the paperwork is fine or not, so I rang them. No update had been given, but I  was reassured that providing the box was ticked on the V750 then the application will go through fine. I've been checking the DVLA website pretty much every day, in the hope that it would have been done. Fast forward to Monday 29th  and I was greeted with a new screen on the check, and it finally showed as Taxed and MOT'd, woohoo! The car was in desperate need of a clean, not knowing when this day was coming it was put off. As far as I was concerned I had another 3 weeks  I'm not normally one for using snow foam, but I wanted to give it another try It hasn't cleaned up too bad considering it's 21 years old and lived on a boat for a number of weeks. The personalised number plate is J2 XBK, an illegally spaced number plate would have it read J2X BK. BK could either represent  the colour black or Baker, which is my surname. I filmed the first drive, the Youtube link will be at the end. I used the same driving route I did with the 323F V6 when I had a new exhaust installed, heres a couple of photos A few more since then Youtube video can be viewed here: https://www.youtube.com/watch?v=TjkFHPzjGDw
