Hey guys got an issue with the GTR i just purchased.
The idle isn't always very smooth.. yesterday when driving back from essendon airport (visited friend) the engine would hesitate then if you wouldnt keep pepping at the accelerator it would stall at low speed.. so then i would roll to a stop and turn it back on, but then again if i didnt keep the revs up it would stall again..
so i would leave it off for a few minutes, then turn it back on.. and the revs would bounce all around from 100-1200 hunting around.. then eventually it would maintain around the 1000revs, but wouldn't really sound right.
then again for no reason it would be fine again.. this all happens once the engine is fully warmed up.
but when its not having the idle issues or like hesitating when driving at less than 60kph then it wanting to stall.. it feels great, boosts strongly and is basically awesome.
im currently staying at my sisters place in brunswick and am planning on driving back to adelaide on tuesday. So if anyone who is in the know wants to check it out let me know :)
Edited by captain_jonno
https://www.sau.com.au/forums/topic/148533-r32-gtr-idle-issues/
The Idle control valve is under the intake plenum (drivers side) it has 4 10mm bolts that hold it to the secondary air system and 1 hose that connects it to the bottom of the plenum. Remove all this then you can get it off and give it a clean. Good place to start anyhow.
Deren
Yeah all the best Deren.
Most Skylines have a 2 speed setup on the fuel pump. Just bypass that by running direct fused power to the pump through a relay, using the regular pump power to operate the relay. See if that fixes the problem.
To me it sounds more like a problem with one of the AFM's. The solder joints inside the AFM's deteriorate with age and with jiggling around whilst driving they can lose contact. This would explain why sometimes the car drives and boosts as per normal and other times, once the contact is no more, you get crappy idling and stalling and basically no drivability.
Theres a tutorial on how to fix GTR AFM's. Sometimes the plugs can be a little dicky also. I just had to replace the top AFM plug with a second hand rb20 one and it works a treat. I even had the AFM repaired and it was the crappy $5 plug.
good luck
Edited by SLIPPERY
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
