post-25018-1166924409.jpgpost-25018-1166924376.jpgpost-25018-1166924275.jpgpost-25018-1166924116.jpgpost-25018-1166924197.jpgjust expressions of interest at the moment people
located at coomera
lookin around maybe 17 k
currently not registered but could be registed again
pm me for any more details or pics OR call
0438977388 or email [email protected]
list of mods is as follows
RB20det
tien coil overs front n rear
cusco front strut brace
KTS rear strut brace
KTS hicas lock bar
KTS 7 point roll cage
KAZZ 2 way diff
splitfire coil packs
iridium plugs
k & n pod filter
nardi wheel
two GTR seats
adjustable castor arms
KTS adjustable tie rod ends
some interior removed
some sound deadener removed
drift handbrake button
full BN body kit
3 inch exhaust form turbo back
rb25 turbo
screamer pipe
front mount intercooler
strobe lights
harnesses
short shift kit
hks electronic boost contoller
apexi boost gauge
greddy exhaust temp gauge (not hooked up)
drift water temp gauge
greddy turbo timer
excedy 550hp big single plate clutch
pumped front guards (35mm)
currently running 12psi and made 212 hp at the wheels
serviced after every drift day
https://www.sau.com.au/forums/topic/148549-r32-4-door-drift-car/
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
