just askin 4 ppls opinions wif dis 1 at the moment i hav an AUTO r33gts(dnt laugh i like it :) )ive just refinanced my loan and wana join the turbo family im thinkin just a sII r33gtst im thinkin of gettin a manual catch is i havnt driven 2 much manual i can basically do it but not very great do you's think its in my best interest 2 get a manual and kinda rough through da 1st couple wks or just stick wif my guns wif d auto is there any major differences perks 4 either all advice would b much appreciated thanx
https://www.sau.com.au/forums/topic/148560-joining-the-family/
I went from 10 lessons in a manual corolla to a r32 manual gtst. There was also a month gap since i last drove the corolla. I found the r32 much harder to stall than the corolla. Hell, the engine lights would come on and I just had to press in the clutch for it to start up again :)
Took about a week to get used to it, and probably another one to not depend on the handbrake on steep hills :pirate:
Get the manual!
Cheers
I went from 10 lessons in a manual corolla to a r32 manual gtst. There was also a month gap since i last drove the corolla. I found the r32 much harder to stall than the corolla. Hell, the engine lights would come on and I just had to press in the clutch for it to start up again :P
Took about a week to get used to it, and probably another one to not depend on the handbrake on steep hills :(
Get the manual!
Cheers
yeh im prob more leaning towards gettin a manual at d moment just not really lookin 4ward 2 lookin like a goose out there on the rd stalling occasionally :)
yeh im prob more leaning towards gettin a manual at d moment just not really lookin 4ward 2 lookin like a goose out there on the rd stalling occasionally :(
haha we all go through that stage. Remembering now, i didnt drive with radio on for the first week as it was too distracting. Had a clutch and gears to worry about without the yacking of a radio :P
Might also get a couple of smells of clutch burning too haha
All in the learning :)
Manuals become second nature within a couple of weeks. it is the only way to go.
that post is so hard to read!?!
sorry mate i probably text to much on my phone bad habit of writing like it i think so couple wks or so should all be good im sure ill be able to get over the embarrassment of stalling if im in a sweet looking car :P i'll probably have to get used to the smell of clutch for a bit to huh would i be in danger of seriously damaging it in those couple wks
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
