A Belated Merry Christmas from me and the missus, as well wishes for a prosperous new year.
For those who were travelling, i hope you all missed the lawful interventions by our friends in blue (i seem to have managed to), and that your trips were safe.
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
