  • Replies 493
Posted Images
what equipment do u have?
i see u've got a 400D but do u konw what lens? or is it the kit lens? do u have an external flash or are u using the built in one?
one of my biggest hobbies (on par with cars) is photography. i've noticed that ur pics are quite underexposed and some could do with a fill flash to bring out more detail in the shadows.
a couple of other hints would be to set your camera on a longer exposure for the night beach shots and put it on a sturdy tripod. use a small aperture (8+) and try to get the horizon lines straight. look up what the rule of thirds is and try using it more. also don't clutter the pictures with too many subjects.
i'm always happy to discuss photography - so hopefully this helps a bit and u can always msg me with any other questions =)
built in flash. I didnt have a tripod with me when i was on the beach, I was resting the camera on a plank of drift wood lol :nyaanyaa:
Alot of night shots that I took, I took without a flash as I was trying to learn how to use the camera.. thats why they are under exposed. Also I wasnt allowed to use a flash for the aquarium shots, but I started using it half way thru anyway.
I have posted what lenses im using in here somewhere, but its 6am and Im to tired to remember right now or look for them haha
  • 1 month later...
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
