  • Replies 493
Posted Images
what equipment do u have?
i see u've got a 400D but do u konw what lens? or is it the kit lens? do u have an external flash or are u using the built in one?
one of my biggest hobbies (on par with cars) is photography. i've noticed that ur pics are quite underexposed and some could do with a fill flash to bring out more detail in the shadows.
a couple of other hints would be to set your camera on a longer exposure for the night beach shots and put it on a sturdy tripod. use a small aperture (8+) and try to get the horizon lines straight. look up what the rule of thirds is and try using it more. also don't clutter the pictures with too many subjects.
i'm always happy to discuss photography - so hopefully this helps a bit and u can always msg me with any other questions =)
built in flash. I didnt have a tripod with me when i was on the beach, I was resting the camera on a plank of drift wood lol :nyaanyaa:
Alot of night shots that I took, I took without a flash as I was trying to learn how to use the camera.. thats why they are under exposed. Also I wasnt allowed to use a flash for the aquarium shots, but I started using it half way thru anyway.
I have posted what lenses im using in here somewhere, but its 6am and Im to tired to remember right now or look for them haha
  • 1 month later...
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
