  • Replies 493
Posted Images
what equipment do u have?
i see u've got a 400D but do u konw what lens? or is it the kit lens? do u have an external flash or are u using the built in one?
one of my biggest hobbies (on par with cars) is photography. i've noticed that ur pics are quite underexposed and some could do with a fill flash to bring out more detail in the shadows.
a couple of other hints would be to set your camera on a longer exposure for the night beach shots and put it on a sturdy tripod. use a small aperture (8+) and try to get the horizon lines straight. look up what the rule of thirds is and try using it more. also don't clutter the pictures with too many subjects.
i'm always happy to discuss photography - so hopefully this helps a bit and u can always msg me with any other questions =)
built in flash. I didnt have a tripod with me when i was on the beach, I was resting the camera on a plank of drift wood lol :nyaanyaa:
Alot of night shots that I took, I took without a flash as I was trying to learn how to use the camera.. thats why they are under exposed. Also I wasnt allowed to use a flash for the aquarium shots, but I started using it half way thru anyway.
I have posted what lenses im using in here somewhere, but its 6am and Im to tired to remember right now or look for them haha
  • 1 month later...
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
