These injectors, are they made by Deatchwerks? is it lik saying im installing nismo injectors, instead im installing Deatchwerks injectors? has anyone used them? what are they lik? cos i lik the price.......
I have these injectors.. works fine for me. i have 240rwkw and max duty cycle i seen is 68%
i highly recommend them, they are high flowed injectors.
They are straight fit.. just like nismo.. fit on stock fuel rail, and comes with flow report of each injector.
Alot of Drag supra's in the states use them
check out their website..
http://www.deatschwerks.com/
Also if you do a search on deatschwerks on any car forum, people seem to say good things about them..
just stay away from Venom injectors.
https://www.sau.com.au/forums/topic/148987-6k/page/2/#findComment-2780025
What size injectors do u have? Im aming at 250kw at the wheels
https://www.sau.com.au/forums/topic/148987-6k/page/2/#findComment-2780033
only had them in for a couple of months. no problems with them so far.
My tuner said he really liked them.
It was about $600 delivered.
you can also get some cashback offer too if you send your old injectors to Deathscwerks so it works out to be even cheaper.. i didn't do this though as i damaged the old injectors trying to pull them off the rail.. haha
https://www.sau.com.au/forums/topic/148987-6k/page/2/#findComment-2780057
ok cool was jus wondering how long they will last for. How long do injectors useally last for
Haha damn, i might be careful taking mine off then haha.
https://www.sau.com.au/forums/topic/148987-6k/page/2/#findComment-2780062
I can't see why they would not last, my stock injectors were fine ( well not after i pulled them out) and i had about 180,000km on the clock.
Just keep an eye on max duty cycle on your PFC controller.
Bear in mind that it will show overall injector duty cycle not individual.
They flow test the injectors thoroughly and my injectors had something like 0.02% variance. Each injector is marked with a number which corresponds to the report.
yeah careful taking out your old ones, you can even pack them in the box that your new injectors came in and send them back to them.
https://www.sau.com.au/forums/topic/148987-6k/page/2/#findComment-2780074
excellent thanks for that, good info. cheers
https://www.sau.com.au/forums/topic/148987-6k/page/2/#findComment-2780078
i'm in.... I'll give them ago
Cheers
So a guess mods rather than rebuild?
I went the mods route.
I got a fair few kms on my car.didn't know if i should sell it or mod it. took it to my tuner and he put the car on the dyno did som test on it and he said everything is healthy and if he was me he would keep the car.
i said i'm worried about the kms on the car and if i mod it something mite go wrong.. he said kms aren't everything you can have a 60,000km car with a bad motor and have a 200,000km car with a much more healthy engine. then i asked him if i should do rebuild first before modding it.. and he said what for? as long as the tune is good and safe you shouldn't have any problems.. alot comes down to the tune.
If you aren't chasing that much power then no need to rebuild what could be a very healthy engine.
anyway just my thoughts.
good luck with your decision.
https://www.sau.com.au/forums/topic/148987-6k/page/2/#findComment-2780298
I'm no guru but it seems u can make good power with a rb25 motor in good condition without the need for new internals..I have been running 250+ for some time with stock internals...I did a compression test recently cos I was bored and everything was the roughly the same as when I got it tested 1 year ago before the mods...
verdict...its ok.
https://www.sau.com.au/forums/topic/148987-6k/page/2/#findComment-2780553
Hey mate what state u in?
Also what time frame are u looking at doing this over?
I'm in vic mate you? thinking anytime from now untill late jan early feb!
they sound like a good deal..
Edited by RPR33
https://www.sau.com.au/forums/topic/148987-6k/page/2/#findComment-2780857
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
