did mine last week. first time using a spray can so considering that im happy. how ever i fu*cked up the plastics pretty bad trying to get the rubber coating off so had to use a few (read "many") coats of spray putty before the primer. actually i used primer first but realised it wasnt filling the scratches so i stripped it back to plastic (i think). anyway i mucked around too much and wasnt too careful. hence theres a few imperfections. it'll last till i can get it professionally done though
oh btw, septone paint thinner works beautifully on the rubber...just pour or wipe liberally and watch the crap wrinkle up right before your eyes. naturally i worked this out AFTER i used sandpaper... :P;)
  • Replies 98
Looks fine mate...if your happy thats all that counts, did mine yesterday looks exactely the same minor paint imperfections.... but hey, i did it in the Kitchen........LOL....not kidding, its to cold outside in the garage over here
Hey i am the same,
Just finished mine yesterday in a metallic electric blue looks the part hey and got the thumbs up from my father in law who is a old spray painter and panel beater so i must have done it ok hey post pics as soon as i can figure it out!!!!!!!!!
hey fellas,
mine is work in progress, found a shit load of old cans in my garage so i made use of em, one looked like paint but had a sticker with "primer" on it. done the three coats but im getin the shits with the ciggarette lighter socket thing, the black housing stuck to it for the light bulb doesnt wanna come out so i shoved a tissue in it and sprayed with it on... hope it turns out ok... im stuck on colour now???????? i got a mirror image of sam's. the silver although done excellent but i thnk is too bright for interior...
thanks for all the help guys. gr8 work...
danny. :dry:
hi
my center consol was already painted when I brought my skyline but im in tha process of doing my interior in red velvetin “like pool table cloth”.tha main problem ive com across is air bubbles because of the glue not being applied evenly, but this is fixable I went and got a seringe an will inject tha air bubble with glue so it will soon be perfect. This is my first attempt at doing an interior and I will post some better pics with a non dodgy camera soon if ne one is interested. Glad to answer any questions
Jon from Newcastle
I would leave it for a while sometimes its the moisture in the glue that causes this.
if no joy, pin prick it a few times and wait a day or two..... just incase its trapped air that cannot get through.
then try your siringe trick but not too much glue otherwise you will soak the covering and leave a stain, or a bigger bubble.
Good Luck .....looks mental
Heres a couple of mine in Super Black KH3....notice the Blue perspex on the Clock and A/C so that it now matches the blue LED i Put in the clocks :)
Edited by Allkiller
I used Blue perspex and cut it to shape....works a treat.
or you can use theatre lighting gel to slide in behind the panels.
Tell you what PM me your address...and i'll send you my old ones i modded with Blue gel in em. hows that.
They pop out real easy when you get down to them. Dash off again im afraid.
  • 3 weeks later...
I thought i'd give this a go seeing as my white dash has annoyed me since the day i got it, I ended up giving up after sand papering for a fair amount of time and not seeming to get anywhere...did anyone else have a problem with the old paint not coming off very easily?? I can get through the first layer of paint but then theres a layer of...primer (i think) that is just being really stubborn to my sandpaper attacks :)
Any suggestions as to how I would get it off or is it just a long tedious task and im too impatient? :D
Heres a trip .. Get the plastic primer and spray it directly onto the painted surface.. Wait about 2 minutes until touch dry and hit it with some 400 grit or lower sand paper.. Watch it strip away before your eyes.. it will make the paint sticky and will come off in large thick amounts .. after you've removed most put it in the sun let it dry for 15 mins and strip the rest back with 800 grit and hit it again with 2000 grit and primer it up and paint..
Dont use paint stripper it will melt the plastic id imagine and it will also create a sticky paint ..
Just note I did it on my r34 .. The r34 paint has to be the shittest paint out .. Melts in hot weather and slight presure from a finger makes it run/smudge ..
So if it doesnt work I suggest using a higher grit sand paper (dont use a sander it will cause deep cuts to the plastic which you'll have to sand out) dont go higher than 400 grit as its already pretty sandy .. when your breaking through to the plastic change to 600+ paper..
Cheers mate
Damn, just had a quick go then and it seems to be a no go, unlucky, this particular paint doesnt seem to be as shit as the r34 paint :rofl:
I tried 400 grit, no go, i even went a bit higher...still barely penetrated the outer layer!
I'm wondering if i should just sand it back as much as i can then paint over the top its already gonna be a semi rough job because the other part to my painting is to try and fix a crack that is in my dash thats about 5ml wide. I don't even know how i'm gonna go about this, i fixed up my front bar with some fibreglass, i'm just wondering if i should attempt to use the fibreglass on my dash or doesnt it bond with plastic? Obviously i don't care how rough it will look, but its better than the sticky tape i had over it before :)
If all else fails i guess i can always get a new dash from the wreckers, i'm just looking for the easiest (read: cheapest) way out of this! I'm already missing having my line off the road :D
Edited by Chaddy
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
