Just an update, I've re-routed my speaker & RCA leads now. It's not perfect but I'd say it's a good 90-95% better, can hear it a bit still when the alternator is loaded up (ie just started the car, headlights on etc). I've also noted that my RCA's are a tad loose on the earth sheild so I need to tighten them up (ie squeeze the contacts in a bit, they're toothed). Wiring also needs a bit more of a tidy up in the boot too.
As far as the speaker wire goes I've still got 1 pair running next to the RCA's (didn't really want to go out & buy new cable to do it the other way) but I don't think it's making a lot of difference, will have a bit of a play around to see what I can do to improve it further when I get time. Technically if the Speaker output is on a properly regulated circuit (ie the amps internal regulated supply), it shouldn't be carrying the engine interferance anyway.
I am actually starting to think the sheilding on the RCA's it just simply inadequate (they are Cadence leads, for those out there wondering & so is the amp).
Sound quality is much better now too due to the thicker leads running to the front now & a bit of amp tuning has gone a long way to helping as well.
Edited by JazzaR33
Hi mate
ive experienced in an r33 that the ground cable has made a difference to engine noise going through the speakers, we fixed this by moving the ground cable away from the relay box and cable tied it in near the roof part of the boot, worth a try good luck.
I would honestly be suprised if you actually have a problemw ith the stock battery terminal clamps.
Even though you might have modified them.
e.g. in my car, i've fitted a sealed lead acid battery. It doesnt' even have posts on the battery. What I did was turn the terminal sideways and put a bolt through the side of it. That's perfect.
Since my car has always ran a sealed battery, i haven't had problems with corroded terminals.
The terminals themselves are fine, corrosion is not.
Whenever peopel see gains replacing terminals, it's usually because they have an under the bonnet battery that isn't sealed and has splashed acid all over the terminals and it has rusted out and not conducting electricity very well.
Yeah admittedly I don't have a sealed battery, but I was experiencing the same issues with the previous battery that was sealed.
As for the terminals, corrosion wasn't an issue, but they were nice & hacked & needed replacing anyway, so thought I'd give it a shot.
As for the solution, there is now 5 things I can see possibly causing the problem:
1. Bad RCA leads (I do know of some1 that changed them & it fixed their problems)
2. RCA leads too close too speaker wiring (I personally find this 1 highly unlikely)
3. Power source to the head unit.
4. A need for a power capacitor for the Amp (400W RMS 4 channel Amp)
5. A need to neaten up the wiring to the Amp
Thanks for the contributions guys
Edited by JazzaR33
Check one more thing for me. I have found this to be the cause a lot of the time.
If you haven't already, i'm sure you know, but rcas on different side to power wire. You should know that already.
One that is always overlooked is the headunit ground. The loom doesn't actually have a ground in it, so it's normally grounded onto the headunit bracket. Check that it's a good ground.
1. Bad RCA leads (I do know of some1 that changed them & it fixed their problems)I think I have some Audioline RCA's (probably made quite a few car audio enthusiasts cringe)
One thing to note though is they have an Amp trigger wire attached to them and I did not use them.
I would remove any unnecessary wires from near it. The small amount of noise you're experiencing my be caused by your speaker wire.
I don't think this would be it but you can always try. I would say it would be more to do with the RCA's as they the weakest signal which would be the most influenced buy interference.
I thought capacitors were only needed for very high end systems, again I could be wrong
I have taken power from the +ve terminal and then earthed the amp to the same chassis ground the battery uses. My RCA's run under the battery and down the passenger side. I was a little worried that it might pick up interference from the ECU wiring but it seems fine. There is some wiring on the drivers side beside the seat aswell and some of the wires seemed a bit thicker than the ones near the ECU so I figured they would affect the RCA's more.
My Amp trigger wire and the speaker wires run together down the drivers side.
Edited by Fry_33
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
