Can't believe he didn't just close this thread...
All computers have slightly different specs. It doesn't really matter that much it would seem. No one ECU has ever stood out as a better performer than the others.
I wouldn't normally dable in a ECU war thread these days as they turn out pointless in all cases, but I thought I'd take this opportunity to discuss E-Manage Ultimate.
E-Manage ultimate was brought to my attention a little while ago ...
If keeping the stock ECU is an option ( as usually is, only if an engine conversion goes down, it may not be ) then the E-Manage ultimate gives the you ignition and injector control.
It DOES NOT appear to work the same as SAFC. SAFC only changes the input into the AFM sensor going to the ECU. E-Manage Ultimate appeared to change the output going to the injectors and the ignition. This means you do have fair greater control and in my opinion, enough control. It also has the ability to use a MAP sensor.
This means it has the same abilities ( when coupled with a stock ECU ) as a true fully programmable ECU, except, it doesn't need a base map. This means its more universal and tuning should be easier.
For around $600 the basic unit is cheaper than the others as it should be, being a piggy back. With a plug in adaptor, its around $750 perhaps?
It does have timing and fuel map full control tho, so its nothing like SAFC or SAFC NEO. Its a clever way of doing what the stand alone ECU's already do ( for most people. as most people do have a stock ECU they are upgrading from, which gets thrown out or left in the car to take car of fuel pump relay or little jobs like that. )
At the end of the day, I'll always remain a "Follow tuners advice" man. However, this new e-manage is a little exciting as it seems to have the goods at a decent price.
A lot of people are scared of the e-manage, I just can't see why...a chimp could program it. I tuned my last car with it when so many other people threw their hands up in the air.
It's so logical it's not funny...need less fuel then reduce the AFM voltage for the given grid point, need more fuel add a percentage extra to the given grid point. Need more timing add extra degrees, need less minus degrees.
I'm talking about the e-Manage ultimate. Not the first one, which is cheaper and I haven't researched.
Sounds like, from what Dan666 says, it works like the SAFC. Where as the Ultimate has greater control from what I can see.
cookiebear - I haven't ever researched the uni chip, although I know alot of WRX's use it, possibly due to MRT seeming to use it alot.
e-Manage Ultimate is a fair bit different in what it can do from the e-Manage Blue from what I have been able to find out so far.
E-manage blue intercepts, but still has a great range of control over timing and injection..with the boost sensor it is extremely good.
I haven't played with the ultimate yet, so I'm not sure what logic it uses to get around the speed cuts etc etc, needless to say it hooks up to a lot more ECU inputs than the blue. It allows individual control over injectors and timing per cylinder..which is pretty good for a piggy-back.
I'm currently using a bikirom though (daughterboard) for full control of the factory ECU
The blue is perfectly capable of getting you over 250rwkw, the ulitmate gives a few extra wank features that you may never use. One good feature though is the 'self-tune' which attempts to steer your AFR to whatever you input, it then adjusts fuel delivery to match...very cool if you can get it running correctly with a permanently fixed wideband O2 sensor. :D
Agree on the self-tune... not much point for everyday users there.
However, you say that the blue controls timing and fuel maps... does it only do this by altering the AFM input signal? Or does it actually send signal out to the injectors and ignitors as does the Ultimate?
If its the former, then I'd suggest there is alot more reasons to go for the Ultimate, leave self-tune aside... actually controlling the timing directly and injectors directly is a big advantage.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
