Originally posted by NisMojo
Hi,
As Slaz said, I am a Focal dealer...and also one for Phoenix Gold.
XrSist, you can pick up a 13 inch Focal from as little as $585
So, not as unaffordable as you would expect....
And, I have just decided that all skylines australia members can have 10% discount. How does that grab ya?
woohoo benefits!!!
10% off wholesale?
just playn...:shake:
https://www.sau.com.au/forums/topic/1500-subs/page/2/#findComment-32531
Guest Crazyfcuk
ive used about 50 kgs of sound deadining in my 33, I used the tar matting from fusion and heaps of dacron (that fluffly white material that the line the inside of sub boxes with - i think thats its name anyway). As its non turb's :D:mad: (i know i know) weight wasnt really and issue so i spent about 3 days doing the whole interior/boot and all. It ended up costing about $350-$400, but now i see it as money well spent. It took ages, but the difference is incrediable, now i can hear hardly any road noise, and the car is quiet as (except for the exhaust which is f#$king loud - not a bad thing tho).
I got pics of the whole process it you want to see it go to http://members.cardomain.com/crazyfcuk
As for subs, i recommend you listen to either subs from the powerplant or johah lomu series, ive used Fusion gear for 3-4 years now and swear by it. Admittly Fusion gear was pretty average when it first came out but now all there gear rocks.
Id highly recomend it to anybody. and after going through about 9 different setups in my old car using fusion gear. I rate it as high as any other. My new setup (2x 15", 3x1000 watt amps, 2x1 farad amps etc...) runs hard, is crystal clear, and goes all day long.
Anyway just my 2 cents worth hope its some if any use to ya.
:burnout:
https://www.sau.com.au/forums/topic/1500-subs/page/2/#findComment-32679
Guest Crazyfcuk
Originally posted by [ryan]
now u tell me
too bad theres no focal or PG in my planned system heh.......
guess the products...... :D
tho i dont know if ill get that deck still, coz its the old model. might get something not as chunky, with mp3 player... but then again im sq junkie and mp3 = not very good quality....
hrmmmmmm
ill look around when the time comes :mad:
What did you do the system diagram with??? I want to do one for the boot lid of my car, and yours looks wicked as. any help would be greatly appreciated.
https://www.sau.com.au/forums/topic/1500-subs/page/2/#findComment-32680
Hi,
Where abouts are you situated?
Are there many models? I always thought there was 1.
Shweeet azzz.... keep the specials rolling in....
https://www.sau.com.au/forums/topic/1500-subs/page/2/#findComment-32689
Originally posted by Crazyfcuk
ive used about 50 kgs of sound deadining in my 33, I used the tar matting from fusion and heaps of dacron (that fluffly white material that the line the inside of sub boxes with - i think thats its name anyway). As its non turb's :D   :mad:  (i know i know) weight wasnt really and issue so i spent about 3 days doing the whole interior/boot and all. It ended up costing about $350-$400, but now i see it as money well spent. It took ages, but the difference is incrediable, now i can hear hardly any road noise, and the car is quiet as (except for the exhaust which is f#$king loud - not a bad thing tho).
:burnout:
Thats one f*&ken sweet setup you got there.. If only i could
weight didn't matter.. 50kg of sound deadener. I assume you
did the doors and roof also?
I've been told FUSION subs are excellent, one company i'm yet
to look up on.
How did you do the bootlid? I've seen very dodgy and excellent
jobs done on this.
https://www.sau.com.au/forums/topic/1500-subs/page/2/#findComment-32690
Guest Crazyfcuk
im still to finish the top of the boot, so far i used shellys space invader to seal up the gaps, and silicone to stop the boot from vibrating. Im in the process of making a custom molded vinal covered trim plate to fit over the whole of the boot lid at the moment, I am going to include a system diagram in the middle, and might put a set of 6 1/2" co-axils in as well (one either side of the system diagram) for a better sound outside the car for when its at shows etc, and when i take the car away, so i can use it to crank up sounds and still have the car closed. I'm going to try and make a switch (fitted somewhere inside the boot so that i dont have to adjust the headunit every time i want to do it)so that i can turn off all the speakers inside the car, and have only the ones in the boot running, Check back at the site soon and ill post some pics when i finish it.
https://www.sau.com.au/forums/topic/1500-subs/page/2/#findComment-32697
just photoshop.
btw most of that **** is audiobahn.. that stuff rocks
helllloooooo 1100wrms SQ sub!
ive got the other model numbers somewhere, i cant remember em hehe.. audio system is like last on my list..
gotta get car first, and then do the engine, then the wheels, then the bodykit.. etc :D
then ill spend big on stereo
better to get it right the first time and buy quality stuff rather than buy cheap **** and replace it every 8 months.
https://www.sau.com.au/forums/topic/1500-subs/page/2/#findComment-32770
Yes, there is a 4 model line up, and the bottom of the range has just been replaced by a range called the ACCESS line. The baskets are made of a mix of fibeglass and ABS! Pretty awesome stuff and cheaper too!
i am in Tasmania, but that is no problem a bit of freight will not fix....
Slaz
https://www.sau.com.au/forums/topic/1500-subs/page/2/#findComment-32779
Guest Crazyfcuk
Originally posted by ultim8DTM5
thats rockford blue, theres also one by stinger...theres also a paint you can get, like g-spot
good for places hard to reach, not a substitute for genuine dynamat...
I agree with ultim8DTM5, they work alright, but outright the dynamat is far better, and it goes on much neater, and looks better when its finished.
All it does is add extra mass to the existing structure thus dampening out sound vibrations, if your going to use some thing that you want to spray on, id recommend some sort of space invader (i think it works out cheaper as well, but dont quote me). I dont know if you guys have Shellys products over there but if you do try theirs. Its messy as to work with but it does the trick for hard to reach places (in the boot lid in those little gaps between the support and the sheet metal). And achieves the same end result.
https://www.sau.com.au/forums/topic/1500-subs/page/2/#findComment-35557
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
