hey guys its usually a simple task i know but ive emptied my master cylinder completely and now i need to rebleed the whole system since installing the r34 brembos and new braided lines. this is a wgnc34 stagea im talking about.
now i have the r32 gtr workshop manual (i only got the jap stagea one so its no use to me) and it shows u need to bleed the abs unit itself, which has 2 nipples on the top of it, but the stagea one doesnt and only has 2 lines on top, so how do i bleed the abs?
obviously the rest is easy and start from the rear left wheel, rear right, front left and front right last.
any ideas on bleeding with the 4 spot brembos which have 2 nipples on each caliper? do i just do the left front wheel first and do the furthest nipple first, then the closer nipple and then the front right in the same order (starting from furthest to closest)???
any info appreciated
https://www.sau.com.au/forums/topic/150058-bleeding-brake-system-abs-unit/
thanks mate but i already have the 32 gtr manual and it doesnt tell u how to bleed the brembos and it says bleed from top of the abs unit nipples in which my stagea doesnt have any and has 2 lines on top of the abs instead that run to the master cylinder.
From memory working on commodores you don't actually have too bleed the abs unit it's done automatically when you bleed all the calipers. You just have to remember when changing your pads not to just push the cyliners back in as it backfeeds the abs unit and f**ks it...Might be the same with the 33's if the units have no bleed nipple on them....
No need to bleed the ABS unit just calipers, and long as you havn't removed or replaced the master you wont even have to bleed that. Its teh same as doing a brake fluid flush, you suck the reseviour dry and just refill it then flush the lines..no need the bleed the master.
If you do run into trouble however you can do a pressure bleed on the master by cracking the lines while you have a helper pump up and hold the pedal.
R33 ABS unit is probably bled with the consult/scan tool electronically
Deren
Edited by Godzilla32
  • Like 1
You just have to remember when changing your pads not to just push the cyliners back in as it backfeeds the abs unit and f**ks it....
So what's the trick to get the pistons back into the calipers safely when ABS is fitted ?
  • 4 years later...
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
