Hi
Just wondering if anyone can suggest to me what this problem is...
My tacho is spastic. It reads fine most of the time but then sometime, especially when under acceleration or going over 110klm's it flicks around or reads very inaccurately. Just wondering if it is a bad connection or a bad electrical part of some sort, since it only happens under certain conditions.
So any suggestions on what it might be? How to fix and how much it might cost?
Francesca
https://www.sau.com.au/forums/topic/150073-tacho-is-jumpy/
what model car? if you ever ask a question about your car, tell us all what model your car is.
u have an R33gtst in your avatar but a lot of people on the forum own or ask questions bout other cars as well :(
i had the problem in my 89mdl r32gtr. it was a faulty speedo cable
https://www.sau.com.au/forums/topic/150073-tacho-is-jumpy/#findComment-2799877
u have an R33gtst in your avatar but a lot of people on the forum own or ask questions bout other cars as well :huh:
Hey
Sorry! Didn't even think of it! Its an R33 GTST... Series 2...
https://www.sau.com.au/forums/topic/150073-tacho-is-jumpy/#findComment-2800781
Hey Francesca,
Ron is right, it'll be your speedo cable. The R32s have it as a common fault based on their age, it is surprising to see a series 2 R33 with the problem.
The speedo flicks back from 110kmh to 100kmh? And sometimes bounces around when driving <40kmh?
Good news is that it is a cheap fix. New cable ($90 for R32) and DIY install.
Mark
https://www.sau.com.au/forums/topic/150073-tacho-is-jumpy/#findComment-2801729
Hey
Yeah its just the tacho that is spastic, nothing wrong with the speedo. Its just that the tacho mucks up either under acceleration (not all the time) and at speeds over 110km...
Maybe it does have something to do with revs but its funny that it would as it doesn't seem to discriminate at what revs it plays up at??
Thanks for your help!
https://www.sau.com.au/forums/topic/150073-tacho-is-jumpy/#findComment-2803272
Hey budy,
my '95 GTS-t S1 does exactly the same thing at about 3400rpm. For me it was physically the tacho, not any wiring. I have a brand new nismo cluster and no worries. But you dont need to spend much money to get yours working, there are plently of instrument repair companies around, or source yourself a second hand cluster.
https://www.sau.com.au/forums/topic/150073-tacho-is-jumpy/#findComment-2803460
sorry to hijack mildly - cowie was that speedo cable $90 from Nissan?
It was in that vicinity at trade/SAU NSW member price iirc.
Guys are paying around $80 for fitting but it is an easy job to DIY and take your wife/gf out for dinner instead :)
https://www.sau.com.au/forums/topic/150073-tacho-is-jumpy/#findComment-2811649
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
    • They are in fact just nozzles. They are there only to produce a spray pattern and limit flow. The injector itself is what I use to control flow to the 7x nozzles. My old system had no injector and only PWM the pump. This lead to a lot of inconsistencies, and poor atomization at low pressure when the pump was ramping up.
