I've got a rb25de non nvcs for sale $800 PM me
comes with:
*throttle body, intake plenum
*injectors, rail, regulator
*camgears, camshafts, valves, valve springs
*cam angle sensor
*coilpacks, loom and igniter
*rb25de manifold
the rb25de head has more agressive camshafts than the rb25det, only difference is the sofer valve springs, I can include some rb26dett valve springs andalso can include rb25de pistons, will give 10.5 compressionratio $100 extra to buyer of the rb25de head
the head has a wiring loom,but it has been severed see pics, needs a new loom or if you find a severed one you could re-attach it , a severed one would be dirt cheap if not free
low km import 56,000km
it does not have nissan valve timing, so you can get a set of adjustable cam gears and see them, rb25 with nvcs has the crank angle sensor and the nvcs blocking them from sight, pictures will explain what i'm talking about
no modification is necessary to the rb30 block or no extra oil line needed for this, straight bolt -on
please note: rb26 clear cam cover needs the backing plate to be cut, all holes and bolts line up little cutting required on some of the corners
*blots not included for rb26 cam cover, i need them for another car
same head as this one http://users.tpg.com.au/cobra30/twincam.htm but costs less
i also have these guages for $150 for the 3, they are japanese
2 omoni guages, water temp and oil temp with senders
1 battle club boost guage with wiring
q45 afm biggest afm for nissan made by jecs japan - $200
or if you want to go non turbo i can get a rb30 with extractors, extractors would need modification to suit a rb25 head -$400
let me know what parts you want by PM, email
hi every one
the rb25de came off a r32 non nvcs straight bolt on to rb30e
also i will include the rb25de water pump and oil pump, but the catch is you have to remove it from the rb25de block, the gear to run the timing belt on the cranshaft is stuck on there really tight would need a breaker bar or special tool to remove
thanks, josh
  • 3 weeks later...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
