I hav'nt been keeping up with the firmware upgrades for my PSP since moving out here and i have a couple of questions for anyone with the Knowledge..
* my last upgrade was the 2.70 firmware, i have now found out that you can get firmware 3.03 so can i just download this version or do i need to download all the upgrades that have been between the two of them :D
*also can anybody advise on a site were i can download the 3.03 firmware??
https://www.sau.com.au/forums/topic/150346-psp-firmware/
go one better, with custom hacked 303 firmware you can do everything 1.5 does but you can also play most ps1 games (ntsc or pal converted to ntsc)
if you currently cant run homebrew you may have to downgrade to 1.5 before you install the custom 303 tho. :cheers:
Edited by midnight
https://www.sau.com.au/forums/topic/150346-psp-firmware/#findComment-2802161
GT2 is currently being played on my PSP.. I don't think there is ANY other game out there for portable console that even comes CLOSE to how good that game is..
I would probably look at getting the custom 3.03 firmware.. i've got a zip of it somewhere if people need it, otherwise search for 3.03 OE-A upgrade..
https://www.sau.com.au/forums/topic/150346-psp-firmware/#findComment-2809860
alot of the ps1 games are better than half the junk on umd.
ff7, ff8, gran turismo 1 and 2, metal gear solid, crash bandicoot. just to name a few
A workmate of mine did my 1.5 to 3.03 upgrade today, it took him 5 minutes. He also put on some old ps1 games on it: spyro, metal slug and raiden. Its pretty amazing, it runs exactly like I remembered it. And to play my psp iso's I dont have to go through Devhook anymore! I cant wait until I get a copy of gran turismo on ps1 and get that going on psp I read that it runs great on psp too
https://www.sau.com.au/forums/topic/150346-psp-firmware/#findComment-2836863
Yay i got Gran turismo 2 working on it, its flawless. Saves are a bit slow, i dont know if thats normal.
However i got an infrigement notice downloading it, LOL because I forgot to load my ip blocker, doh.
Title: Gran Turismo
Infringement Source: BitTorrent
Infringement Timestamp: 21 Jan 2007 05:35:33 GMT Infringement Last Documented: 21 Jan 2007 05:35:33 GMT Infringer Username:
Infringing Filename: Gran Turismo 2 (U) Psx Infringing Filesize: 464974305 Infringer IP Address: xxxxxxxxxxx Infringer DNS Name: xxxxxxxxxxxxx Infringing URL: http://www.spanishtracker.com:2710/announce
https://www.sau.com.au/forums/topic/150346-psp-firmware/#findComment-2843056
^^ Bahah bad luck dude. I also downloaded GT2 and got it working on my PSP, but I used to play it heaps on PS1 back in the days. The save times are exactly the same, but atleast it works hey.
By the way: http://pspupdates.qj.net imo, is the best PSP site, just to add another!
-Brent.
https://www.sau.com.au/forums/topic/150346-psp-firmware/#findComment-2844137
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
