im fairly certain std rb25 headgasket is 1.2mm thick, and a 86.5mm bore first oversize (20 thou), 85mm stroke, 87mm headgasket bore size, 62cc combustion chamber head, 11.5cc dome and the rb25 piston will sit 1.2mm below deck height...not sure if i worked that out correctly though. I based it off CPs which i believe have a 0 deck height. Then i worked out 8.7:1.
Yours is a little less cause your oversize again at 40 thou over. But then your CC size is 5cc smaller. So it bumps it back up again.
I use to work it our manually until i was pointed to this site which helps alot....saves all the maths on the paper and in my head.
http://www.csgnetwork.com/compcalc.html
I just worked ours out with the cps and i get 8.2:1 CR which is exactly how they advertise them. So i know this calculator works good. That and it worked good when i rebuilt my rb25 with acl forgies. I just worked out an rb30det with acl 25 pistons with your 34 neo head and at 40 thou over with a 1mm hg i got bloudy 9.6:1CR.... thats gibson motorsport gtr territory there.
Ok one more time...Spool did the rb25 pistons have any dome on them or were they flat as a tack? Cause im pulling the specs off the acl website for their pistons. If its wrong then it could explain the weird CRs im getting in comparison to what your getting.
Edited by r33_racer
sorry I was working on acl rb30et piston
which has -4.5cc dome, 0 deck height , a compressed gasket usually works out at 1mm compressed, 88.8 mm gasket bore size ( the last few Ive had measured this )
and the more oversize you go the higher comp ratio you end up with as your swept volume increases.
So with the ACL RB30ET piston with a R33 RB25 head you end up with close enough to 8.0:1 comp - plus or minus as every engine differes a little, depending on actual comb chamber volumes, compressed head gaskets ( depending on brand etc )
Its a very precise calculation.
interesting on the headgasket...i was under the impression that a 1.2mm gasket is 1.2 when compressed. And my 1.6mm headgasket is 1.6mm when compressed. Well that .2 difference makes a difference to the CR.
My apologies, your right about the higher comp to volume increase. I had it back to front.
I was working everything off rb25 pistons not rb30et ones.
with the head gasket - I am referring to graphite gaskets. So when u meausre it on the bench, it will definately be less when compressed. A laminated steel one should theoretically be what it is advertised at. So like u said a 1.2mm should be 1.2mm when compressed. But never take it for granted, it is easy to measure with a small piece of malleable lead or similar.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
