hay guys i wanted to know if there was a webstite anway where on the laws on mods in vic state..
i have afew question with mods
i was speaking to afew people and they said you can only have 1 intake mod e.g if ihave a fmic and a cai
i can only have one ?
are we allowed to have these mods if we get engineres certificate?
and what else are these cops ganna pick on =)
cheers
https://www.sau.com.au/forums/topic/15048-laws-on-mods-in-vic/
  • Replies 43
they'll pretty much pick on anything they like
ive heard stories of people getting dicked for not having a H pattern on their gear knob
bov that vents into the atmosphere is a no no
air filter even
bald tires
steering wheel
head lights being too blue (actually being white but they think it looks blue)
no third brake light
the list is endless
and yes you can only have one air intake mod
if you want to have both just chuck the original airbox over the pod
Vicroads vehicle standards information guide is about 30 pages long and can be accessed by clicking here
There is a search function, and you may be able to find what you are after by searching for it, or you may have to go page by page.
Other documents can be found here
http://www.vicroads.vic.gov.au/Home/RulesS...rdsInformaiton/
P.S, I left that last link as the url to point out that VicRoads dont know how to spell "information" :P
Guest INASNT
fark the police/epa man do what u want to your car, infact it is yours and u did pay $$ for it. If u get caught then put it back to normal, then put it all back on after the tests.
I did :D
They wont be picking on imports in about 2-3 months cause bracks pockets will be full of $$ by then. When its emptys he can always got the BS 3km/h speed cameras to rake in more $$
It's not worth the hassle.. some people want to get their car how they want it, and leave it.
They don't want to screw around with changing stuff every time they get pulled over. :D
What a pain.
Just get it how you like it, and leave it!
yer the poice are beyond tight on import cars, i have also heard they are blitzin the import market, that is bein harsh on da imports
some of these rules are kinda dodge though....the air filter one for example, if u have a pod, its illegal but if u put some form of box on it...its legal? meh, i just dont get it
no no no no no!
*sigh*
Pod filters are legal, providing they are paper element filters.
Oiled filters are not EPA legal.
EPA also says that you are only permitted 1 modification on the intake... so apparently if you have a turbo, you aren't meant to have a pod filter.
What a load of..... :bs!:
Guest INASNT
Originally posted by R31 Skyline Chick
no no no no no!
*sigh*
no kylie if your car came with a turbo stock, then u can have 1 intake mod, ie a fmic.
Kylie???
um.. well let me see... pod filter or intercooler...... now.. which one would people choose????
I think most people would prefer to have the intercooler and run an Apexi paper filter pod. ;)
Aftermarket steering wheel is legal providing that the diameter of that wheel is not smaller than 33cm across. My momo race wheel is 35cm across so it's legal. Many aftermarket steering wheels are offerend in two sizes, 32cm & 35cm. The 32s are not legal.
This is based on RTA vehicle modification guide. I dunno about vicroads but I suppose the size standard should be similar. But if you have airbag as standard equipment, you're not allowed to change your steering wheel unless you have written permission from Dept of Transport (or RTA or Vicroads ?) before you do that.
you guys mentioned vic roads rwc? before?
i wanted to ask when my car gets complianced and the enginer comes in etc
if its got an fmic in it which it does exhuast etc cold air intake steering wheel
does he pass it?
and then what happends with rwc do i take it to vic roads
how the hell are they ganna know whats legal and wats not all the poeple that work there are just stupid?
i dont understand? what they look for?
if you want information on the legalities of turbo timers (which aren't legal in Vic :) ) then call the Police station and ask to speak to a TMU member.
watz wrong with a turbo timer??? :D Bloody pigz.......Alwayz c em running red lightz....bastardz..
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
