Hey all,
I have for sale a full set of used Yokohama Super Advan Racing SA3R wheels. Very hard to find these rims as they are out of production...
Came off an S14 but will suit almost any application.
Specifications:
Size: 17x8 (front), 17x9 (rear)
PCD: 5 x 114.3
Offset: +35 (front), +38 (rear)
Center caps and valve stems included
Made in Japan
They are in fantastic condition with minimal to no gutter rash and come wrapped in KUMHO ECSTA 235/45R17 tyres. Basically brand new (95% tread remaining).
$1200
$1100
Located in Adelaide, SA.
Can be delivered to your door ANYWHERE Australia wide for $100!!
PM with any questions/queries.
Edited by driftKNG
https://www.sau.com.au/forums/topic/150541-sold/
simmyb: Not gonna take the tyres off man. At the least, might as well use em up for a bit of thrashing or a regency job...
Darkboy: They def aren't 4 hole mate, must just be the angle of the pic.
JAS-25T: They are light mate, but not that light! >_< That is the weight of each rim... Tyre would add another 4-5 odd kg...
Edited by driftKNG
https://www.sau.com.au/forums/topic/150541-sold/#findComment-2806070
    • I downloaded the apps (for windows) and Consult 1 doesn't have this function on it for the Consult 1 plug which I'm pretty sure all Skylines have. You would think someone would have a workaround after 30 years for all Skylines which have ABS.
    • Also, I don't know the actual ABS system on the skylines, but a sneaky thing could be a piece of electronic equipment that makes the ABS think you're moving, and then same piece can send a signal for a locked up tyre... Activate ABS without slamming brakes...
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
