  • Replies 51
You bring 'em, I'll wear 'em.
This offer may or may not be redeemable on the day of your choosing, with or without alcohol incentive, in a public place or in private, without express medical permission. Keep chops out of reach of children.
thanks for the b'day drink Andrew and the many b'day hugs :P
and thanks to matt and nick for there b'day hugs also hehe.
i ended up getting a free Schutzenfest cup thing :( hahah yeeeeeeeeeah.
man i'm so tired.
oh yes i didn't get drunk, was almost there but pfft, next time
oh also, how many of you went to shade 3?? :no:
haha oh that was hilarious Andrew :)
Edited by pokie
I am glad to hear you were under Nick - I thought you were safe otherwise I wouldn't have let you drive home from my place :(
No worries Amanda, hope you enjoyed your birthday celebration!
Yes, I was a bit drunk and my directions giving left something to be desired, but you gotta expect that :huh:
Owwww my head today!
I got a good gbanger shot but it's on my phone and only for private use - I SMSd it to Pawley/Mel, as Mel is usually the one who gets the good Schutzenfest shots :)
LOL at the "three years running" feeder type shots.
Was disappointed to have to leave earlier than I would have liked, although my wallet did thank me. We spent a hundred bucks in the 3.5 hours we were there as it was, and I was driving!
Missed seeing the birthday girl, but I was told she'd be there by 5 and we didn't leave until 5:30, so we tried.
Was a pretty poor turn out compared to previous years numbers, but a good time seemed to be had by all there.
yeah tried to get there by 5:30pm but we missed the Schutzenfest shuttle from Vic Sq
it's all good though :unsure:
Good day all round, great to catch up with those in attendance, what time did the rest of you head after Julie and I disappeared around 8?
was good seeing you again, was good to meet your gf also :huh:
i think me and vanessa left around 9pm possibly a tad later then that
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
