Seen these before? Easily remapped? Anyone even got one? ~800 for a trade in ur stock ecu for one of these sounds ok...
http://www.mines-wave.com/english/products...cpu-nissan.html
I asked Mine's and they said this is only part they hold for ECR33's. They are still alive and kicking.
https://www.sau.com.au/forums/topic/150744-mines-vx-rom/
I dont know where you get $800 from, but you need to check your exchange rate. 96,000 yen is just over $1000 plus shipping of your ecu there, plus weeks wait while they send one back, plus the shipping back. It would be over $1200. plus it's just a re-map of a standard ecu. you could do it here for less (hell you get buy a power FC for less) and at least whatever you did here would be tailored to your car and aus conditions.
https://www.sau.com.au/forums/topic/150744-mines-vx-rom/#findComment-2805344
There must be some benefit though. I mean you pay ~800 (because I did conversion... dont make this an argument about conv rates its about vx-rom.) and you trade in your ECU for this one, it has to be something better than just be a Mine's part.
Do you pay the amount just for a re-mapped ECU and a Mine's sticker on it? I sent another email to Mines to give me all the features about the ECU. They got back to me within 2 hours last time so well see.
I got to say I'm a big fan of Mine's tuning, they do a fantastic job on their cars.
https://www.sau.com.au/forums/topic/150744-mines-vx-rom/#findComment-2805389
go ahead and buy it, but i can tell you, it's just a remapped standard ecu with speed limit removed, rev limit raised, fuel cut removed and mapping suitable for higher boost. and yes the price is relevant to this thread. 96,000 yen is over $1000AUD plus you have to pay for shipping both ways and do without an ECU for a few weeks. a power FC for instance which is readily tuneable can be had for around $1000 AND you still have your old ecu so no time spent off the road, and when you swap you can sell your old ECU for say $150. Total cost then is $850 + tuning.
I also think mines are a great tuning company, but buying a pre-tuned ecu from another country, from a tuner that has never seen your car is not a smart idea. taking your car to mines and getting them to map a chip for you in real time on the other hand would be great. if you lived in japan that is.
and FTR I have previously used a mines ecu in one of my cars.
https://www.sau.com.au/forums/topic/150744-mines-vx-rom/#findComment-2805660
^^ his right mate. i also love the mines tunning shop & their work. but honestly better to get a power fc and get it locally tuned. i sold my power fc that came with my car because it wasnt tuned and i didnt have the money to tune it at the time so i bought a mines ecu. i 100% regret doing that hahaha. dont get me wrong the mines ecu is good for bolt ons (exhaust air filter etc), but once u start doing injectors/afm etc u'll need something that is re-tuneable.
https://www.sau.com.au/forums/topic/150744-mines-vx-rom/#findComment-2805810
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
