under the private import scheme, are left hand drives eligible? or are they striclty right hand drive only? from recent memory, only classic cars were eligible for registration...like pre 1970..at least in SA it was like that.
If its possible then it opens up Euro import options for me, as theres a stack of cars here in Japan that go pretty cheaply...can anyone advise on this?
https://www.sau.com.au/forums/topic/150787-private-import/
I was just about to edit my post on your other topic...
I am sure that you can register it with a restricted plate, unless it is a classic as you mention.
It does open your market up much more when looking for Euro cars in Japan, but I would tend to stick to RHD.... it will make your life SOOOO much easier
https://www.sau.com.au/forums/topic/150787-private-import/#findComment-2806253
Like I said in the other thread Personal Imports are subject to state rego requirements.
e.g. In NSW you may be able to register a LHD vehicle under 4.5 tonnes GVM if:
- it's more than 30 years old
- or it's not required under law to be RHD
So something like a Mitsubishi Eclipse (if you chose to waste the Personal Import scheme on a car like that :laugh: ), would need a RHD conversion in NSW.
https://www.sau.com.au/forums/topic/150787-private-import/#findComment-2806298
ive driven a couple of LHD here..not too bad. A guy i know took me for a spin in his 190E 2.5 litre 16 valve evolution 2. do you know this car? maybe you remember it from Gran turismo..
what a car. damn thing had active suspension, like the old williams F1 cars used to have..engine was simply glorious, too. That thing was LHD and you mentioned the car would have to be rare and collectable...id say that 190 would qualify for that!
https://www.sau.com.au/forums/topic/150787-private-import/#findComment-2806309
You can import pretty much anything you like as a 'personal import' as long as you have awned and used it yourself while living overseas for at least the past 12 months and are returning to live in Australia again afterwards.
Once you have the car in Australia then you have to meet the normal registration requirements in your state - usually this means minor compliance type work to make sure the car meets ADR's and unfortunately this includes it being right hand drive unless it's over 30 years old (15 years old in WA)
https://www.sau.com.au/forums/topic/150787-private-import/#findComment-2806311
So something like a Mitsubishi Eclipse (if you chose to waste the Personal Import scheme on a car like that :( ), would need a RHD conversion in NSW.
sounds like you want me to do your dirty work for you! :laugh:
30 years old eh..... :D
not "required" to be RHD,...? what would qualify a car for that concession?? can you give other examples??
https://www.sau.com.au/forums/topic/150787-private-import/#findComment-2806325
so if what youre saying is true, anything built after 1977 will have to be converted to RHD?
https://www.sau.com.au/forums/topic/150787-private-import/#findComment-2806342
Here are the state requirements..
NSW: http://www.rta.nsw.gov.au/registration/dow.../vsi40_rev1.pdf
VIC: http://www.vicroads.vic.gov.au/NR/rdonlyre...A48/0/VSI18.pdf
WA: http://www.dpi.wa.gov.au/mediaFiles/IB-106A.pdf
etc, etc
google "left hand drive" + the name of your state licensing authority.
https://www.sau.com.au/forums/topic/150787-private-import/#findComment-2806367
I'm positive its the same for Sunny QLD too...
30 yrs.... or get a restricted rego (for club events, track days etc).
I understand what you mean... they are great to drive, and not that hard to adapt to driving LHD...
what I meant was it would make it so much easier for you regarding registration if it was RHD.
https://www.sau.com.au/forums/topic/150787-private-import/#findComment-2806409
oh, i wont bother if its going to be such a hassle. when i was a kid my old man went to the trouble of converting a seven series BM he bought back from germany and it was sitting in parts in the shed for ages. im NOT going to bother if its going to be that big a headache..
Yet, i wonder how much conversions cost in Oz... :laugh: and would it be worth it?
Razor, i come from SA. Ill try your tip on the google engine tho. cheers for pointing out my lack of common sense! :)
https://www.sau.com.au/forums/topic/150787-private-import/#findComment-2806900
^^^ I don't recall the conversions being cheap at all.... I have a feeling there was a place in central QLD that did a lot of the American Corvettes or something... I'll try and find their site for you. I guess you could google it as well and see what comes up.
It wouldn't be something I'd like to try myself either.... I would make a mess of it!!
https://www.sau.com.au/forums/topic/150787-private-import/#findComment-2812316
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
