  • Replies 64
Posted Images
Hey all, im back from my holidays.
Yudy you know i live and work not far from racepace so i will come down ONCE ITS ALL DONE AND OUT OF THE WORKSHOP hehehe.
Pm me for my mobile number, then you can just give me a quick call when its nearly done and ill pop around.
Simon
https://www.sau.com.au/forums/topic/150811-racepace/page/2/#findComment-2809493
Simon
not a problem will do.
Hei Ska is my typing that bad>! LOL
https://www.sau.com.au/forums/topic/150811-racepace/page/2/#findComment-2809900
hei guys ,
alex and other people who wants to meet up this afternoon please PM me your mobile details to me please ? so that i can call you guys later on. Thanks
hey guys i have just moved to meblorune how many stagea's are going to be there today would be good to meet u guys
https://www.sau.com.au/forums/topic/150811-racepace/page/2/#findComment-2816463
so, how did the tune go?
there was a bit of hick up during the tune but this is laargely due to the cam gears i supplied ben with. Its all good now should get the car back about after lunch. Will keep you guys updated once i get the car.
https://www.sau.com.au/forums/topic/150811-racepace/page/2/#findComment-2826102
well i got the car back.
First impression it sounds normal and stuff but when you drive it its a whole different car.
Throttle response is much quicker and crispier. Turbos spool faster. Torque is crazy planted my ass onto the seat when you step on the gas pedal. I like it :sorcerer: . BTW Mods i did to the car Power Fc, original boost controller, Cam gears, Drop in panel replacement filter and a full 3" exjaust system with a high flow cat.
Bottomline it maxed out at 236.5kw@4wheels.
Will post the dyno result tommorow.
Edited by stasis
https://www.sau.com.au/forums/topic/150811-racepace/page/2/#findComment-2827627
Bottomline it maxed out at 236.5kw@wheels.
Holy Snapping Duckshit Batman!!!
You would have to be happy with a result like that. I don't suppose there would be any chance of a peek at the dyno sheet? Kinda interested in the torque curve from a result that good.
https://www.sau.com.au/forums/topic/150811-racepace/page/2/#findComment-2827740
Here it is the dyno result
Edited by stasis
https://www.sau.com.au/forums/topic/150811-racepace/page/2/#findComment-2827799
Impressive graph, good midrange.
I am sure he sacrificed some top end for the midrange, but thats a very very streetable tune and favorable to the extra kg's of the Stagea
/good to meet you today
Well nice to meet you too today. Im sure with have shot loads of things to disscuss.
Well when i first called Ben in Racepace i told him what i want and how im goign to drive it. I told him im looking for durability and realibility thats the priority. Then i told him that this was goin to be a street car mostly 1st, 2nd and 3rd gear ( cant go any faster than 110km/h anyway :) ) . Hence the result of the tune. I drove it again this evening its a bit scary though when the power comes on on the 2nd and third and i have to back out on the gas pedal.
Pverall im pretty pleased with it despite it didnt make the 250kw@wheels. But its enough i guess. Enough to kill the FPVs and the HSVs drivers. muahuhauhauhauahahu!!!!!! :dry:
https://www.sau.com.au/forums/topic/150811-racepace/page/2/#findComment-2828408
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
