Hi All,
I tried using the search function but it had difficulty searching on C4 so I thought I would post my question instead.
I have a Nissan 180sx with an SR20DET in it. To majority of the Nissan 4 banger crowd auto is a swear word, but word has it the C4 in the Skylines crowd is not such a foriegn concept.
Just trying to find out who built your boxes and if you would recommend them, who you would stay away from etc.
Also would be handy to know what internal mods were done to the boxes i.e trans brake etc
Did you have any relevant issues with the conversion that might be handy to know even though it is a different setup.
Thanks in advance.
https://www.sau.com.au/forums/topic/150991-c4-auto-into-nissan/
Hi All,
Thanks in advance.
talk to richard at craft differentials (02) 96371973 or (02) 9682 7222 he will be able to help you out.
also you could try dellow automotive (02) 9774 4419
i have used both before and are very good at what they do
I currently run one of Fred's Stage 3 C4 auto's behind my RB25DET and love it to death. Fred is a trans guru and a top bloke to boot! He is also an agent for TCE converters and deals with them every day of his life so the service you receive from them is excellent too. (as opposed to dealing with TCE directly).
If you'd like to discuss it, send me a pm or email.
Cheers,
Adrian
Cheers,
Adrian
I have only just started looking but my first impression was he seemed like he knew what he talking about.
He did recommend the TCE convertor as part of the package. I am looking for a full manual auto. Fred said he did one in reverse pattern.
Also trying to work out if it is worth spending the extra $800 for a trans brake / upgraded billet valve body.
How do you find the TCE convertor? does it stall nicely? what is the top end slip like?
You can get both forward and reverse pattern C4's in full manaul operation. The difference occurs if you want to use a transbrake. Fred's transbrake valvebodies are reverse pattern, billet, and super tough.
The converter is too loose for my setup but that's not a measure of it's quality - more a case of us not tuning the car with a manual first to discover the exact characteristics of the engine combination. You usually have to chase the converter a bit in turbo cars (especially turbo&nitrous cars) so i was prepared for this. My converter will go back to TCE to be tightened after the next street meet i go to so we know exactly how much to tighten it up by.
I thought that losing 2 gears and a clutch was going to make the car less fun to drive.....
....oh how wrong i was :worship: I couldn't be happier with this box. It's worth noting that Fred replaces every bearing in the C4 with a needle roller bearing for added reliability and longevity. Something which not every gearbox builder does.
In my very brief call to him he seemed to replace any part that was of importance. I am seriously considering running a blower in conjuction with the GT3076R I have on the engine so I would really need to sort out that first before I do anything.
Once I have dyno sheets I would have a better idea of what was required from the convertor. Are you running a trans brake or not?
I have the following box from Protrans:
Ford C4-C10 Transbrake: High Performance 3
- Transbrake reverse shift valve body
- Vasco 26 spline input shaft
- Roller bearings throughout
- Raybestos bands and clutches
- Kolene steel forward clutch pack
- Special heat treated race steels high gear
- Billet race servo
- New 4 pinion low drag Billet planetary (Optional 6 pinion)
- Modified high gear drum for high RPM
- New rear servo piston
- New Sprag assembly
- Race modified lubrication oiling system
- B&M alloy pan with Hi-Flow TroqueFlite filter
- AN-6 fittings
That sounds like the bits he quoted me on. I was given a price of $3800 for a transbrake box and $3000 for one without. Although that is a fair bit of money once you add $1000 - $1500 for a convertor and other bits and pieces it should be a fairly bulet proof box.
Funny how people have the misconception that driving an auto can't be fun. They obviously have never driven a decent one.
I am pushing to justify the extra $800 for the transbrake, but it would work nicely with my MSD which has a 2 step built in :D
Sounds like Fred might be the go unless someone pipes up and has something to say that would talk me out of it. Thanks for your help.
BTW are TCE charging for the tweaks to your convertor?
Edited by AWD2Go
I think I would be hard to beat off the lights :D
Just have to see if the budget stretches that far it is nearly another grand, if it was strictly a strip car it would be easy to justify just not sure I can justify it for the street.
What stall did you wind up going with? Fred spoke about doing mine with an 8 inch convertor to get the stall but keep it tight.
I am going to be using the same C4 setup as 2rismo when i get my ass into gear. My car has already been tuned and dynoed with a manual so now i know when it comes on boost (close to 6000rpm >_<)
When when when when?!?!? I'm dying to see the cars full potential
You need to meet him. That will solve your apprehension. :)
I think I am a little apprehensive because so called "experts" very seldom live up to my expectations. I generally find if I want something done right I have to do it myself (custom steam pipe manifold which I am currently getting done is a prime example, it was a case of this is what I want now please weld it up). I build all my own engines because I just dont trust anyone else to do it right.
Auto are a bit of a specialty item and although I have done some minor mods myself before (shift kits, basic rebuilds etc) there is a huge difference between a shift kit and a full performance rebuild. Some tricks are only learned with time.
As soon as I get mobile again (hopefully in the next couple of weeks) I can start on my supercharger project and then I will have a much better idea what sort of stally I require.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
