Hi Guys,
Had my car on the dyno today getting my pfc tuned. Asked the mechanic if we could run it on 12 psi.
This afternoon when I went and picked it up he said that he could not get any more than 9psi. He said that he thinks one of the waste gates was stuck open, does this sound right. It's a 32 gtr with standard turbos and a manual boost controller. Chris
https://www.sau.com.au/forums/topic/151108-boost-problem/
A stuck wastegate will stop you running higher boost for sure but if your mechanic/tuner can't ascertain the nature of the fault then you might want to consider taking it somewhere else. A good mechanic/tuner is worth his/her weight in gold, especially when talking boost.
Have you ever been able to run more than 9? Does it have a stock computer (My 33 GTR has the stock boost restrictor in place but was running 13psi - found it had an aftermarket computer).
2nd opinion can never hurt, try to find someone who knows Imports and particularly GTR's.
https://www.sau.com.au/forums/topic/151108-boost-problem/#findComment-2812727
THANKS it has a power fc, i got a feeling he put the boost controler on the wrong line no matter how much you ajust it still the same boost.
https://www.sau.com.au/forums/topic/151108-boost-problem/#findComment-2812793
Did you install the PowerFC? Are you sure there's not a boost control module for the PFC installed somewhere?
It does sound like he's doing something wrong though, you should be able to vary boost by 'some' amount if it's on the right line. I've not fitted a controller to my GTR (only had it a week) but on my Series II GTS25T it was installed on the vacuum line between the Intercooler pipe work and the Wastegate actuator. Make sure it's installed the right way too, if it's not it will boost all over the place and you'll be picking up RB26 pieces =\
Edited by ActionDan
https://www.sau.com.au/forums/topic/151108-boost-problem/#findComment-2812853
yeh i put the pfc in but it's the same with the standard one.may have to start pulling shit off and have a bit more of a look.
https://www.sau.com.au/forums/topic/151108-boost-problem/#findComment-2812884
I'd be getting a second opinion before you start ripping it apart. Try to find a reputable tuner/mechanic with Import/GTR experience. Explain the situation to him so he can inspect the wastegates and go from there.
Good luck, let us know how you go :huh:
https://www.sau.com.au/forums/topic/151108-boost-problem/#findComment-2812913
The issue of safe boost level on stock ceramic GTR turbo's is a contentious one. Many people have safely run about a bar with no issues, many others have reported turbo failures and in some cases engine damage from ceramic dust being ingested. The decision is yours but be warned that pushing the ceramic turbo's WILL reduce their life and increase the risk of failure as does pushing any component harder.
https://www.sau.com.au/forums/topic/151108-boost-problem/#findComment-2813078
yep i wanted to run at about 12.
https://www.sau.com.au/forums/topic/151108-boost-problem/#findComment-2813135
Doesn't the power FC have its own ebc therefore eliminating the need for the manual one? I got my car tuned to 13 psi and i had the power fc and eboost hooked up. The eboost was controlling the boost levels but when i went to pick the car up the engine light was on. The mechanic said "oh that just happens to skylines with the power fc" which i didnt take kindly since i entrusted my car to him. I came on here "SAU" and found out that the power fc has a boost controller that u can turn off with the hand controller. I did that and BAM! engine light gone...
In all maybe the power fc boost controller and manual boost controller are crossing paths and playing with your boost level? Perhaps disconnect one and see if theres any difference.
Matt
https://www.sau.com.au/forums/topic/151108-boost-problem/#findComment-2814610
Matt
maybe he has put the boost controller on the wrong hose.if i was looking in my engine bay what hose should the boost controller be on?at the moment it's on a small hose under the intake.
https://www.sau.com.au/forums/topic/151108-boost-problem/#findComment-2815546
Matt
The PowerFC Boost control is a separate part you purchase (the solenoid).
Its the same thing that the Apexi ACV-R uses.
So you need to actually purchase the solenoid separate, and then install it.
It doesnt come with the PowerFC itself
https://www.sau.com.au/forums/topic/151108-boost-problem/#findComment-2815554
na i dont have pfc boost controller just one of those GFB ones.
https://www.sau.com.au/forums/topic/151108-boost-problem/#findComment-2815581
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
