Hi
i got a Tein HR come off my car for sales
TEIN HR Colicover suspension with Pillow Ball Upper Mount. $1100
90% nearly brand new, good condition
can fit on NISSAN/GTS R33/GTT ER34/GTR34
cheer
https://www.sau.com.au/forums/topic/151224-tein-hr-fs-gtsgtt/
you can get these new from jap for less than 1100 mate...
Hi
cheer
Hi, do you know what spring rates they are? Can you verify that they are 90% new? Do you have a receipt and do they come with warranty (these have 2 years warranty standard). Like JimmyR33 said you can get brand new ones from Greenline for $1,100 with warranty.
If you will do them for $800 delivered to Adelaide consider them sold :laugh:
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
