just put my engine back in for the 2nd time as i had an issue with the valves,(dont ask)
put it all back in this week, just needed oil and a spark plug as my mate dropped it,
started putting coolant in and opened the bleeder up, blah blah blah, noticed a big puddle of coolant on top of inlet port 1, thought it wass the orings so i put some new ones in, tried it again......
turns out that the brand new tomei metal inlet gaskets i put in 5/6 are good but the 1 inbetween the head and the inlet is leaking, GRRRRRRRRRR.
not keen on pulling the motor out again just to do that,
Have any of you Guys used metal gaskets on teh inlet?
Did you use sealant as well?
Jeremy
https://www.sau.com.au/forums/topic/151284-not-happy-jan/
Oh the wonderfull world of fixing the bloody skyline. Good luck with it. I've got a coolant leak in a bitch of a spot. Starter motor has to come out to get to it.
yeah i know, theyre nothing but.. got it going yesterday arvo, no leaks or anything, but got a tappet noise at cylinder 6, which is where repco machine shop put in my new valves, not happy because the clearances havent been set right, i hate engine noises, makes you look bad when your driving,
done about 18ks now,
make sure you dont lie underneath the starter motor when you unbolt it, cause the coolant puddles on it and then when it moves it goes all over you(as i found out yesterday) lol
https://www.sau.com.au/forums/topic/151284-not-happy-jan/#findComment-2820749
'make sure you dont lie underneath the starter motor when you unbolt it, cause the coolant puddles on it and then when it moves it goes all over you(as i found out yesterday) lol'
Thanks for the warning. That's what it's doing!
https://www.sau.com.au/forums/topic/151284-not-happy-jan/#findComment-2820852
as with all metal gaskets you should use a hylomar spray on them.
and 3 bond around the coolant areas.
thanks Dave, i learnt that one the hard way,
All good now, changed the plugs as 4 were cracked, going great again, but with slight tappet noise from cyl 6
https://www.sau.com.au/forums/topic/151284-not-happy-jan/#findComment-2821200
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
