U'r lucky this is SAU and I'm not an admin here :)
I meant that people have replaced seals and then the car has done a Turbo shortly after.
which seals are we talking bout here? gaskets or turbo bearing seals?
btw pulling the front and rear off turbos are easy n wont stuff anything up.. if u start pulling the cartridge apart thats when ull have troubles
https://www.sau.com.au/forums/topic/151313-my-gtr/page/2/#findComment-2816651
Kushil - My Series II only had POD (enclosed, cold air feed and heat shielding foam) Turbo back exhaust and the factory dual stage boost bypassed so it would run 7psi all the time. At a guess, the car would've made 140-145rwkw's? It had Bilstien Shocks, King Springs, 265 rubber (rears 235 front) and a strut brace so it was fun to drive having come from an NA FWD Celica. The R makes my Series II feel like a stock NA silvia. The power and handling is not comparable. I friend of mine who drives a fairly modded 185awkw WRX explained that he didn't want to race me on the strip or track after going for a ride in it.
I was under the impression that moving into a GTR would just be a heavier, slightly better handling and more powerful Skyline but the difference between the two cars is much bigger than that. Drive one and you'll understand better, good luck on your purchase!
NB: To be fair, the R has more mods than my last car by the way.
Bugger.......ya...i got the same sort of mods in my GTST...no cold air shilelding though....and still on factory boost...probably a bit slower than you car.......
thankx for the info..
NB: To be fair, the R has more mods than my last car by the way. I am preety sure it has ???....
https://www.sau.com.au/forums/topic/151313-my-gtr/page/2/#findComment-2816676
I have always seen the 33's as a 'not rare enough for me' type car, maybe its just GTST's. But when I see the GTR's up close and in Midnight Purple I start to like them more and more.
But counting all the 32GTR's in Australia now I'm not one to talk :O ..... :P
https://www.sau.com.au/forums/topic/151313-my-gtr/page/2/#findComment-2817281
    • Why are people so insistent on making dirty water?!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
